1/72 B-52D "Big Belly" Racks
Posted by Bish on Friday, August 24, 2012 1:41 PM
Is this the same as the one you sent me last month.
    April 2012
Posted by Striker8241 on Friday, August 24, 2012 3:12 PM
It's an updated version. There's a table at the end of the document that indicates what was changed.
    February 2010
Posted by Bockscar on Saturday, August 25, 2012 4:15 PM
Fantastic work Russ!
Many thanks for the updated clip manual.
I really appreciate your descriptions,
your technical drawings, the photos,
and your WIP pictures.
A highly valued contribution to my BUFF
file.
Some work to do:
I need a few more details, and to cut away the upper bomb bay doors:
Cutting away those uppers will make detailing a whole lot easier.
-Dom
Posted by Bish on Saturday, August 25, 2012 4:28 PM
Thanks for the updated version Russ.
    April 2012
Posted by Striker8241 on Saturday, August 25, 2012 8:00 PM
Bockscar
-Dom
My pleasure, Dom. And thank you for the good words.
Russ
    April 2012
Posted by Striker8241 on Saturday, August 25, 2012 8:01 PM
Bish
You're welcome, Bish. Hope it's useful to you.
Russ
    February 2010
Posted by Bockscar on Saturday, August 25, 2012 10:28 PM
Some shots for the Dayton BUFF:
Picture taken at aft, looking at forward bomb Bay, note the wheel well to the left, that's at the back.
A view of the fore bomb bay section:
Note the Air Force Museum has used a darker green, but I don't know shishka from bob on on the paint:
Hmmmm....card stock.......suspicious, eh Russ?:
Also I think the upper doors were closed at the time I took these. The staff didn't like it when I jumped up and slapped the inside BB either....lol....Devil
    April 2012
Posted by Striker8241 on Sunday, August 26, 2012 9:49 AM
Bockscar
Great pictures, Dom! Thanks!
Bockscar
As I remember, the color of the anti-corrosion green paint varied throughout the plane, probably due to aging and to changes in color specifications over the years. The paint I used is lighter than olive drab (the color of my bombs) which is probably a good thing as the bomb clips should stand out better against the walls of the bomb bay.
Bockscar
Lol yep Big Smile
Bockscar
Lol! You naughty boy! You are correct, Dom. The upper doors remained closed and locked except when loading bomb clips, special weapons, or nukes.
Russ
Posted by Bish on Sunday, August 26, 2012 10:05 AM
Striker8241
Bish
Russ
O don't worry, it will be. It might be a few years before i get round to building my B-52, but i will deffinatly be keeping this info on file.
    January 2003
Posted by yardbird78 on Sunday, August 26, 2012 7:34 PM
Last summer I visited the SAC museum in Nebraska and took a bunch of pictures of the B model B-52 on display there.  This web address has most of those pictures of the landing gear, LG bays and bomb bay.  The B model is structurally mostly the same as the C,D, E & F models.  One major difference is this B model has the twin 20mm tail turret from the B-36.
Darwin
www.britmodeller.com/.../index.php
The B-52 and me, we have grown old, gray and overweight together.
    April 2012
Posted by Striker8241 on Sunday, August 26, 2012 7:55 PM
yardbird78
Darwin
Many thanks for the link, Darwin. Those photos are excellent!
Russ
    April 2012
Posted by Striker8241 on Wednesday, September 12, 2012 2:41 PM
Hello, All,
I discovered that my design of the bomb clip panels was slightly off. The front and back of the panels are slightly tapered toward the bottom. This was easy to miss since the pictures I had to work with were mostly at an angle and the tapering was hard to see. The picture below (65675034400_002208_3.jpg from the Critical Past site (http://www.criticalpast.com/)) clearly shows the tapering of the panels. I will correct the dimensions in the next version of the assembly manual.
Cheers,
Russ
    November 2010
Posted by Son Of Medicine Man on Wednesday, September 12, 2012 6:02 PM
Striker8241
Hello, All,
I discovered that my design of the bomb clip panels was slightly off. The panels actually taper toward the bottom. This was easy to miss since the pictures I had to work with were mostly at an angle and the tapering was hard to see. The picture below (65675034400_002208_3.jpg from the Critical Past site (http://www.criticalpast.com/)) clearly shows the tapering of the panels. I will correct the dimensions in the next version of the assembly manual.
Cheers,
Russ
Hi Russ,
That is the trouble with trying to find the right photograph to show what you need.  At least you did find it, good work!  Now that you found it, it does make since that it would follow the shape of the fuselage.
Ken
    April 2012
Posted by Striker8241 on Wednesday, September 12, 2012 7:34 PM
Son Of Medicine Man
Hi Russ,
Ken
Thanks, Ken. Actually, the tapering is front to back, not side to side. Can't see what advantage that gave them unless it just saved on material costs or maybe weight. It could also be that the bomb lift trailer could only accomodate the size used for the cradle, so the clip panels had to be tapered to fit on the cradle.
Russ
    November 2010
Posted by Son Of Medicine Man on Wednesday, September 12, 2012 7:53 PM
Striker8241
Son Of Medicine Man
Hi Russ,
Ken
Russ
I see that now that you point it out.  I agree that does seem odd and would not be something you would expect.
Ken
    April 2012
Posted by Striker8241 on Saturday, February 16, 2013 10:25 AM
Hi, All,
I recently dismantled my prototype bomb clip and rebuilt it. I corrected the shape of the panels and simplified them so they are easier to build, plus I left off the I-beam edging around the outside edges and the slot as it was out of scale anyway. I also added the chafing curtain between the right and center panels which I left off in the prototype.
In the original build, I had problems keeping the bombs straight when attaching them. I solved this by adding a 1 mm strip of plastic as a "shackle" (see pictures). This also enabled me to mount the bombs so the fins are oriented correctly.
NOTE: For further updates on these bomb clips and transporters, please see my diorama thread at:
http://cs.finescale.com/fsm/modeling_subjects/f/19/t/149616.aspx
My sincere thanks to you, Andrew Magoo, for allowing me to use your thread so shamelessly Big Smile. I wish you all the best!
Cheers,
Russ
