compressors
    May 2003
compressors
Posted by nsclcctl on Thursday, August 7, 2003 9:45 AM
Stupidity strikes again. I have been buying cans and cans of compressed gas for airbrushing. By any chance, does a compressor also go by the name "Vacuum pump"? The reason I say it, I have a lab and we have pumps to create vacuums attached to instruments. One inlet creates the vacuum and a second line pushing air out. Is that per chance a compressor that can be attached to a airbrush?
Posted by dubix88 on Thursday, August 7, 2003 1:50 PM
HEY,
I dont know but if your looking for a compressor try ebay.
Randy
THATS MY VOTE "If a woman has to choose between catching a fly ball and saving infant's life, she will choose to save the infant's life without even considering if there is a man on base." -Dave Barry In the words of the great Larry the Cable Guy, "GIT-R-DONE!!!"
Posted by cnstrwkr on Thursday, August 7, 2003 2:29 PM
You need to check the psi output of the one pushing out and monitor it. If it is a steady reading of a psi you can work with then it should be no problem. If the psi is steady. You can put a regulator on it so you can select a desired working psi. Good luck
Tommy
Tommy difficult things take time...the impossible, a little longer!
    January 2003
Posted by leemitcheltree on Thursday, August 7, 2003 9:29 PM
I don't know that a vacuum pump will be the best option - I guess it depends on the CFM the pump is able to draw and it's duty cycle.
In general, vacuum pumps (in their typical applications) run for limited periods, whereas air compressors are often designed for continual use.
I'd opt for a compressor over a vacuum pump any day, and if you can, get a slightly larger unit than you think you'll need - and get one with a holding tank. That way, your airbrush draws off of a continual, steady supply, and not a "pulsing" supply, providing a smoother paint flow into whatever you are painting.
Try Wal-mart or Sears for a small unit with a holding tank attached - I got a similar unit here in OZ for under $200.
Cheers,
LeeTree
Cheers, LeeTree
Remember, Safety Fast!!!
