Vickers Valiant - Mach 2 in 1/72nd
    May 2004
Posted by mikeiw on Wednesday, May 17, 2006 5:40 PM
Well - I got the BIGGEST box from Hannants this morning, with my Mach 2 Valiant in it... oh, and a few tins of Red Arrows Red for my Gnats & Hawks.
The kit box is a large flat affair, with a rather simple pic of the bomber on the front as it leaves a mushroom cloud behind it... kind of says a lot about the purpose of the Valiant really.
Inside, there are 2 sprues of quite brittle plastic, with quite a grainy surface overall.  Ther panel lines are adequately scribed, if a little deep for scale, but then aren't ALL panel lines at 72nd scale?  There's quite a bit of flash on some of the smaller parts, and also quite a few areas of the tail section in particular that seem to have an uneven surface.  Fortunately, the panel lines are deep enough to survive what will necessarily be quite a sanding & buffing job when the time comes.  There are also quite a lot of ragged mould seams across the trailing edges of the wings, but with a little careful sanding they should disappear nicely.
The cockpit is surprisingly well detailed, however the ejection seats are the most flash covered pieces of styrene I've seen in a long time.  A better choice would be a set of Aeroclub metal seats of the appropriate mark.  The wheel wells are also quite well detailed considering the reputation of the manufacturer, and with a little extra detail to busy it up will look quite nice.  The clear parts are again flash strewn, and a little rough, but with the windows being so small, this will hardly notice once they've been futured.
The decal sheet is small, and the decals are tightly packed as a result.  The Valiant wasn't the most heavily marked plane in history, so all the sheet consists of are a few roundels (with separate centres) and some codes... nothing much else, really.  They have a kind of yellowed look which even extends to the clear carrier film, a bit like the ancient decals you get from an old Matchbox kit, so I'm not looking forward to using them.  The yellow tint may look a bit silly against the anti-flash white scheme I'm planning on doing in honour of the only surviving Valiant thats at RAF Cosford.  I was lucky enough to get up close & personal with her just after she was re-assembled, and my good friend Dave, who works there even managed to get me a load of "in-progress" shots as she was rebuilt.
The parts are still on their sprues at present so I've no idea about the fit of the parts yet, and I've not had time to take any pics as yet. To me though, it looks like a Valiant, but will need a lot of work, particularly on the surface finishing to make a good model.
More news later.
Posted by djmodels1999 on Thursday, May 18, 2006 1:22 AM
Have fun!
    May 2004
Posted by mikeiw on Friday, May 19, 2006 3:05 PM
Cracked open the box tonight, and did a parts fit test... BOY are those Mach 2 kits wobbly!!! Shock [:O]
As you can see by the preceeding pics, there's a lot of warping in the parts.  The fuselage is like a banana, as are the wing roots, and there are large ejector pin turrets on the inside of most parts, some of which actually prevent the parts from mating.  They were all nipped off, and the whole looks rather good, if you ignore all the warping.  The plastic has an odd gritty surface, and occasionally, on the top of the fuselage and the vertical tail especially, there is a noticable undulation in the surface of the parts... that will require some diligent sanding & filling, for sure! Wink [;)]
The pic above shows the weird angles the wings attach at present.  Partly due to the warping of the wing root, and partially to the hastily taped bits... nothing that can't be fixed with some styrene shims.  If you look closely, you can probably see how the root of the wing inboard of the intakes is gaping nastily.  That will probably require some reforming in hot water, as it could quite easily pop open if I just glue it together.
Moving on to the small parts:
The uneven surface continues over to the canopy, but with a little buffing it'll hardly notice, especially as the windows are so small on these V-Bombers (gotta love 'em Wink [;)] )
Not a bad job on the cockpit, although the seats are infantile, and the interior probably isn't accurate.  Not much will show through those tiny windows though, thank god Big Smile [:D]
The wheel wells are actually quite nice, although they suffer a little from under-filling, due to the thin walls in places.  You can see on this one where one side hasn't formed properly, and has a wavy top.  Also, there's a hole in the base, where an ejector pin has gone straight thru!
The turbine face isn't too bad, but I've not actually checked how it fits into the wings... I'm sure it'll need PLENTY of filler!
A small sheet, with a bit of a creamy white that doesn't really show up on this pic.  If they don't work, it wouldn't be a difficult job to replace them with some generic AM decals.
What do I think after having a pore over the plastic?  Terrible quality control, and awful fit awaits me, but I'm going to enjoy EVERY minute of it.  Where else can I find a 1/72nd scale Valiant?  Aim27? Ask them again in 6 months if they've got any vacform kits made up yet...
Here's the inspiration:
I have a whole host of pics that were taken early this year, just after the last surviving Valiant was transported to Cosford & rebuilt Big Smile [:D]
    May 2005
Posted by StarTux on Thursday, June 1, 2006 11:20 PM
Nice review! I ought to be getting one in a couple of weeks or so. According to Hanannts this was the biggest and fastest selling kit Mach 2 has ever produced. Lets see if this new batch has similar issues to yours. It can only get better or worse it seems!
MJH
    April 2005
Posted by MJH on Friday, June 2, 2006 8:20 AM
Shame about the quality - 'bout what I expect from a French kit though.  I was looking forward to featuring this kit in the club mag but now I'm having second thoughts.  Do you mind if I quote some of your comments in a brief overview?
    May 2006
Posted by ian lanc on Friday, June 2, 2006 11:17 AM
hello mike,  i hope you've got the patients of  a saint !!!  in building that valiant, i built a avro shackleton once, and i could not get one of the wings level no matter what i did and i have never liked it,  talking about doing 'vacformed' models have you seen on 'EBAY', there is an  I.D MODELS 1/32 LANCASTER here's a link to that model, i would love but wouldn't entertain it !!!!!,  link
http://cgi.ebay.co.uk/ID-Models-1-32-Avro-Lancaster_W0QQitemZ6061829160QQcategoryZ70105QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
just doing one more model ! thats all.
Posted by rjkplasticmod on Friday, June 2, 2006 12:35 PM
Sounds like a bit of a challenge Mike, but that's how we hone our modeling skills Smile [:)].  Keep us posted as the build progresses.
Regards,  Rick
    May 2004
Posted by mikeiw on Friday, June 2, 2006 1:51 PM
Go right ahead, I'll get my agent to give you a call  Wink [;)]
Seriously though, pinch whatever you like from it, even the pics, and if you mention my name, you'll make me very happy Big Smile [:D]
Also, if it's online, just drop me a link to the page, as I'd love to see it.
    May 2004
Posted by mikeiw on Friday, June 2, 2006 1:53 PM
I do have the patience of a Saint, but I think he knows I've got it, so he's looking for me Blush [:I]
Mmmmm.... 1/32nd Lanc.  I've seen someone building that puppy up.  Looks GREAT Big Smile [:D]  Might watch it, and if it doesn't go to silly money, put in a random bid... bet it does go for silly money though! Sad [:(]
    May 2004
Posted by mikeiw on Friday, June 2, 2006 1:55 PM
...In fact, that's Gunpowder from ARC, unless it's the biggest coincidence in the world Shock [:O]
I'm surprised he's given up on it... he was doing really well last time I saw it... quite sad Sad [:(]
MJH
    April 2005
Posted by MJH on Friday, June 2, 2006 8:31 PM
Thanks Mike;
I included the kit in my new releases this month with a short caption but I know it would interest some people to learn more about it - being the 'lost' V-bomber.
I'll put in a half-page item in the next month or two based on your experiences and drop a couple of your pic into it (with due accreditation of course!).
Not on line yet, but I'll get your email  when it's done and send you a PDF.
Michael
    May 2004
Posted by mikeiw on Saturday, June 3, 2006 3:24 AM
 MJH wrote:
Thanks Mike;
Michael
Smashin'! look forward to it  Big Smile [:D]
    May 2004
Posted by mikeiw on Sunday, June 4, 2006 6:02 PM
Got busy with the sanding sticks & micro-mesh cloths today, cleaning up all the major parts just to see how bad they were.  The good news is that after the funny mould lines were removed from the trailing edge of each wing, and various places on the fuselage, they polished up nicely, and won't need too much extra work.  I also heat-formed the worst wing root so that the air intakes line up better.  The other wing was simply a case of poor fit, so a good bit of sanding later, and that one fits fine Big Smile [:D]
There are a few bits that didn't form properly, due to airlocks or insufficient pressure on the injector, such as the horizontal tail, where one tip is round while the rest are square... go figure!
The pebble finish on some of the parts is proving a little more troublesome, and the vertical tail is the worst part.  There's a little of the same surface on the top of the fuselage, but here's a pic of the tail after a coat of Squadron white & sanding.  You can see that the Mr Surfacer has remained where the low points are.
Most panel lines on the tail have been re-scribed, and will probably have to be done again before I'm finished.  I'm just waiting for the latest application of Milliput to set, and then I'll be at it again with the sanding sticks.  I've decided against using Squadron again, as it takes paint differently because it's semi-porous on the first application.
I'm enjoying the work so far though, and have even glued the air intake trunking together, so I can get to work on making some servicable intakes... that'll be fun from what I can see! Shock [:O] I've also cleaned & glued up the Aeroclub ejector seats that'll be in the cockpit instead of the crappo kit parts.  Next I need some cockpit pics to see just how accurate the kit tub is Dead [xx(]
MJH
    April 2005
Posted by MJH on Thursday, June 15, 2006 7:47 PM
Very quiet on the Valiant front....  How's it coming?
Michael
    May 2004
Posted by mikeiw on Friday, June 16, 2006 2:57 AM
Oops!  Forgot to post an update Oops [oops]
I've decided to try & make a more accurate shaped intake & trunking.  The kit intakes once you've cleaned them up, whilst not as bad as they first seem, have a slightly "off" profile, and the main intake splitter is a little too blunt & too far forward.  I've trimmed mine down a bit, and tacked the wing together with CA.  In the photo below, you can see some red modelling clay stopping the RTV from leaking everywhere.
I've also filled the round hole inboard of the intakes, as that's just a depression on the real thing... see here:
And here's the mould box that I filled with RTV and plunged the intake into!
Now I wait 24 hours to see what comes out of the mould....
Popped the kit parts out of the mould box to rapturous applause (aka silence), and poured in some resin after chopping the intake ducts to the right length.  Here is the first master from which I'm going to fabricate the more accurate profile...
They're rough & ready presently, but I'll start sanding & filling them into shape shortly.  Next task is to repeat the process on the other side, so I'm making an accurate pair.  Yet another night of lego bricks & gooey RTV rubber  Dead [xx(]
Posted by midnightprowler on Friday, September 29, 2017 3:38 AM
Was this build ever completed?
Hi, I am Lee, I am a plastiholic.
Co. A, 682 Engineers, Ltchfield, MN, 1980-1986
1 Thessalonians 4:13-18 1 Corinthians 15:51-54
Ask me about Speedway Decals
