Stripping Future
Stripping Future
Posted by Anonymous on Tuesday, February 4, 2003 6:24 AM
What can be used to strip Future from a clear canopy without damaging the canopy? I dipped the parts of an Me 109, but I don't really like the results, and I would like to try again.
Any Suggestions?
Posted by weebles on Tuesday, February 4, 2003 6:34 AM
You should have no problem removing it with rubbing or denatured alcohol. Just remember that if you're using water based paints the alcohol will attack the paint. I haven't had a lot of experience with this so hopefully others will have some ideas.
Posted by Anonymous on Tuesday, February 4, 2003 10:15 AM
Yep, alcohol has worked for me. I've also heard windex will work too. I assume your canopy is not attached yet, which will make the whole operation much easier. If it's already attached, I would recommend 'popping' it off somehow and working with it off the model.
M.
Posted by Anonymous on Tuesday, February 4, 2003 10:43 AM
I think I read the future bottle and it said to remove with ?amonia? of course that was for floors so I don't know if amonia will jack up the clear plastic or not.
Posted by Anonymous on Tuesday, February 4, 2003 5:14 PM
Thanks for the help! The parts are not installed or painted yet, so it should not be too big of a deal. What happened is the future puddled up in the recesses between the glass and framing, leaving a line there when it dried. By the third part, I got good at using a rag to absorb the excess, but being a perfectionist, (which is a bad habit) with your help, I'll get it right this time!
Thanks again!
