ADC Gray?? Correct Shade???
Posted by Silverbird01 on Monday, August 11, 2003 5:10 PM
I'm building a couple of Century Series jets(F-102A and F-101B to be specific) and wanted to know whats the most correct ADC gray on the market? I normally use Testers Modelmaster paints but the Aircraft gray (FS: 16473) looks a little too blue to me.Is this about right or should I lighten it a little?? Pictures I have seen show it to be more gray than blue. I know,I know you shouldn't rely on printed photos but I need some help on this.
I would really appreciate any assistance. Thanks!!
Steven
Posted by BlackWolf3945 on Monday, August 11, 2003 5:33 PM
FS 16473 is, indeed, the color you're shooting for.
The only birds I've seen up close in this color were F-4's and F-101's. Both were the same basic color, but different shades. The F-4's seemed to be a bit less blue than the 101's and I'm sure that it varied slightly from unit to unit and even jet to jet. Many factors can affect the appearance of several aircraft painted the "same" color; time and place of painting, paint used and subsequent conditions to which each aircraft is exposed.
Now, I've got four bottles of Testors Aircraft Gray 16473. Two are the same and one is lighter and one is darker. So it's not just photos that you have to ponder over, it's the paint as well. Heck, I've even got multiple copies of alotta decals and some dupes are different.
So in the end, if it's really important to you, I'd say gather up all the evidence you can. Weigh it all in the balance and come up with a happy medium that satisfies you. If you think that your bottle of A/C Gray is too blue or too dark, add a bit of white when you go to spray. Experiment a bit and try to come up with what you like and what you think looks okay.
Fade to Black...
Posted by Silverbird01 on Monday, August 11, 2003 7:47 PM
Blackwolfscd,
Thanks for the detailed answer. I appreciate the help. I should have figured that the paint would have faded being outside and in the weather. Photo's can also fade and change with age. I will do as you suggest!
Thanks!!
Steven
Posted by berny13 on Monday, August 11, 2003 8:38 PM
Steven
Modelmasters FS 16473 is the correct color. The paint was very fade resistant and held up very well. It was easy to clean and always had a gloss look.
I have seen color photo's of aircraft painted in ADC gray and the picture looks like the aircraft is white. I have heard the expression, "Photographs do not lie". Oh yes they can.
Berny
 Phormer Phantom Phixer
On the bench
