Trump F-105D Finished
    January 2004
Posted by MusicCity on Saturday, July 1, 2006 7:46 AM
It took a long time to complete because of some personal issues I had to deal with over the past few months, but I finally finished Trumpeter's F-105D.
Here's one photo:
and there are about a dozen more on my web site at This Link
It was built for a man who flew them in combat in Vietnam and carries the tail number and aircraft name of the airplane that he flew.  He specifically requested no panel line wash, no "Remove Before Flight" flags (except the one on the pitot tube since it's steel and I kept poking myself with it!), and no weathering other than some soot stains inside the speed brake petals, so that's what he got.  He picked it up last night (06/30/06) and I think he was pretty pleased with the results.
This one was a lot of fun to build, even though it took much longer than I expected.  It has a ton of aftermarket parts on it which made it a bit more difficult, but all in all it went together quite well.
    January 2003
Posted by Gumiflex on Saturday, July 1, 2006 8:28 AM
Music,
I check rest of pic's, that is master work done.
Gumiflex
    July 2003
Posted by KJ200 on Saturday, July 1, 2006 9:20 AM
Scott that is one awesome build.
Thanks for sharing it with us.
Karl
Posted by rjkplasticmod on Saturday, July 1, 2006 9:32 AM
Excellent build Scott.  Well done!!
Regards,  Rick
jwb
    February 2006
Posted by jwb on Saturday, July 1, 2006 9:38 AM
OK- admit it. You invented a shrink ray.
Wow!
Tha tlooks great. The office looks real- not just life-like, it looks REAL. Amazing work. I know he'll display that proudly for many years.
Jon Bius
AgapeModels.com- Modeling with a Higher purpose
"For I know the plans I have for you," declares the Lord, "plans to prosper you and not to harm you, plans to give you hope and a future." ~ Jeremiah 29:11
    November 2004
Posted by brain44 on Saturday, July 1, 2006 10:09 AM
Scott,
Simply outstanding work on the Thud!  The level of detail (especially the 'pit) is unbelievable; I wish mine looked 1/100 that good!  I would certainly HOPE that your customer was satisfied, if not, he is nuts!  Thanks so much for sharing, and BTW, your photo work is every bit equal to your building skills!
Brian  Cowboy [C):-)]
"I won't be wronged, I won't be insulted, and I won't be laid a hand on. I don't do these things to other people and I expect the same from them." John Bernard Books (The Shootist)
Posted by Melgyver on Saturday, July 1, 2006 10:09 AM
Fantastic job!  I looked at your "G" too on your site!  Amazing work!  I've got a buddy who was Crew Chief on F-105's, maily Wild Weasels.  I've been after him to dig out his slides so I can make him a model of one he crewed.  I final got out of him that he crewed 5 aircraft, one a "D" and "lost" 4 of them!  Had to be tough on to have your bird and pilot not come back after a mission.  Now he is battling his second round of cancer.  I should go ahead and build him a "G" from his Unit.
Clear Left!
Mel
    March 2005
Posted by philo426 on Saturday, July 1, 2006 10:25 AM
Great Work!Did you use aftermarket metal landing gear and how much weight did you add to the nose to allow it to sit right?
Posted by wibhi2 on Saturday, July 1, 2006 10:45 AM
I can't add anything more glorious than what has already been stated.
Thanks for the picts.
3d modelling is an option a true mental excercise in frusrtation
    January 2004
Posted by MusicCity on Saturday, July 1, 2006 11:44 AM
Thanks everyone, I really appreciate the comments.  The pit is all aftermarket.  The seat was made by Legend Dimensions and the rest is mostly a color photoetch set from Eduard.  I admit I did spend a ton of time on the cockpit and was pretty pleased with the results.
Philo426, the landing gear is metal.  The nose gear is from Aeroclub and the main gear is from Scale Aircraft Conversions.  The main gear set, for some reason, doesn't include the nose gear whereas the set from Aeroclub does.  The owner provided the Scale Aircraft Conversions set but I was concerned about the nose gear because I was adding a bunch of weight up there.  I had an Aeroclub set left from my F-105G and I used the nosegear from it.
I think I added about 6 ounces of weight as far forward as I could get it.  The owner purchased a resin fin correction kit and all of the M-117 bombs are resin.  I was concerned about all that weight behind the CG and added a bit more weight than I needed.  Five ounces probably would have been enough, it was slightly nose heavy when finished, but I wanted to be on the safe side.
Mel, I agree to both points.  You should build him a plane and it must be terribly rough to not have them come home from a mission.  I'm sure the pilots and crew chiefs tend to get somewhat attached, and it has to be rough when one doesn't come home.  Build him one, by all means.  If you have questions let me know because I still have an "Expert" I can call on to answer them.  Joe flew virtually every version of the F-105 except for the pre-production model.  He has been an absolute wealth of information on this one and if you have a question I can get you an answer.
Brain44, he wasn't actually a "Customer".  He contacted me and asked if I would be interested in building it.  I told him I would and that if he provided the kit and aftermarket stuff he wanted used that my price would be $0.  I don't build them for profit, only for fun.  He told me that he would not hear of it, and I just said we'd work something out at some point.  He snuck one in on me though.  I mentioned that I wanted to build an F-15E as an Israeli F-15I.  I came home one afternoon and there was a big box on my deck.  It contained a Tamiya F-15E (1/32 scale, of course!), a ton of aftermarket goodies, and three different sets of decals.
Thanks again guys.  I appreciate the comments and I'm glad you enjoyed the photos.
    July 2004
Posted by mucker on Saturday, July 1, 2006 2:03 PM
Scott, what a great build. That must have taken a long time. The cockpit is outstanding. It will be the centerpiece of any room or display case.
    April 2004
Posted by crockett on Saturday, July 1, 2006 7:32 PM
Scott,
It's all  been said already, but I'm impressed. Congratulations. Outstanding build.
Steve
    February 2005
Posted by MA Cooke on Sunday, July 2, 2006 8:49 AM
Scott, an absolutely stunning build.  You, Swanny and Pix produce some of the best work I've seen (OK, there's that guy in Paris who did the F-18 diorama...).  Can't wait to see your next project.  I wonder when an F-14 will make it's way onto your bench?  And knowing you, it'll be REALLY DIRTY!  Ha ha.
Mitch
On Bench: AM P-51B, Tamiya 1/48 F4U-1A On Deck: Hasegawa F-14's (too many); Tamiya P-47D; Academy P-47N;
    March 2004
Posted by Mark Joyce on Sunday, July 2, 2006 9:00 AM
Beautiful work, Scott!  I'm sure 'her' pilot was immensely pleased with the end result.
Mark
Ignorance is bliss
    January 2004
Posted by MusicCity on Monday, July 3, 2006 5:02 AM
Thanks guys, I appreciate the comments very much.
It did take a long time to build, 7 months from start to finish, but a lot of that was because I had some issues I had to deal with and just couldn't focus on a model.  The kit itself goes together quite well and isn't that difficult to build.  The owner had purchased a ton of aftermarket goodies for it (about 12 different PE and resin sets) that took a good bit of time as well.  The cockpit itself took a lot of time to complete because it was pretty difficult.  As I mentioned, it's all resin and photoetch and if I counted right there are about 120 pieces in the pit alone.
Mitch, you've put me in some pretty illustrious company that I don't deserve ;)  I am heading into your era though since the next one will be either an F-15C that I started last year or an F-15E that will be built as an Israeli F-15I Ra'am.  I might get around to doing a Tomcat one of these days.
Mark, I think he was pleased.  I've badgered him to pieces with endless questions over the past 7 months so I know I got most of the details to his specification.  I sprayed color swatches and sent to him prior to painting anything and got his approval.  We adjusted the bottom color a lot until I got it where he wanted it.  The decals were custom-printed and reflect "His" airplane name and tail number.  The ordnance loadout is what he said he typically carried on a mission, and so on.  All in all it should be real close to being what he wanted.
I didn't realize it until he picked it up, but he has spent over 2 years on this project.  He has already had one built and didn't like the end result, so mine is actually the second one he's been through.  I think he got what he wanted this time though because he said it was going home, into a display case, and never get moved again.
I had a blast building it, and it was great meeting a real live fighter pilot.  Glad you guys like it and I appreciate the comments.
    February 2006
Posted by Wulf on Monday, July 3, 2006 6:42 AM
From time to time, life gets in the way of modeling. However, your work looks great. Thanks for sharing.
Andy
Posted by Anonymous on Monday, July 3, 2006 10:02 AM
Great looking job on the build.
    May 2005
Posted by Bgrigg on Monday, July 3, 2006 12:09 PM
Scott, that Thunderchief is fabulous! Your work blows me away. I've been waiting for updates on this build for a while. The office is one of the best I've ever seen!
However, you are flat out WRONG if you don't consider yourself in the elite group of modelers here at FSM. Mitch is spot on with his assessment (and that goes for Matt (Swanny) and Bill (Pixilater), too!
So long folks!
    January 2004
Posted by leadsled on Monday, July 3, 2006 2:28 PM
Beautiful! (sniff,sniff) Just an absolutely beautiful leadsled!
    October 2005
Posted by shaun68 on Monday, July 3, 2006 4:09 PM
Mate, that is some seriously top drawer work. Outstanding!
    January 2004
Posted by MusicCity on Tuesday, July 4, 2006 7:49 AM
Thanks guys.  Once again, I appreciate it very much.
Bill, I've been waiting to get it done for a long time to ;)  It was just plain a lot of work because of the quantity of parts in the kit and all the aftermarket stuff that was used.  The "Construction Notes" at This Link give an idea of some of what was involved.  Glad you like it, but I still disagree with your assessment.
    April 2005
Posted by wing_nut on Tuesday, July 4, 2006 9:14 AM
Must be something about the Ohio air, or my borther-in-law's PC, but I can't see the pics or even get to your website.  I'll check when I get back to "Joysey".
Marc
    April 2005
Posted by wing_nut on Tuesday, July 4, 2006 9:35 AM
Well I did not have to wait until I got back.  GoToMyPC is an amazing program.  I just looked at the build on my PC at home...450 miles away.  I wonder why I can't see it from here htough... I can see everything elseConfused [%-)]
So now I can say...GREAT JOB
Marc
    September 2005
Posted by leadsled757 on Tuesday, July 4, 2006 10:03 AM
Beautiful Build considering how much work has to be done to the original kit.
I'm a big fan of Republic Aviation.  I built a Monogram F-105 kit for a friend of mine who flew the "THUD" out of Tahkli, RTAB.  He didn't fly up North as the Phantoms had pretty much taken over that roll by the time my friend arrived but he did fly "in-country", over Cambodia and Laos.  The model sits in his law office in Clearwater, FL.  I've some great copies of the pictures he took and my favorites are of his "THUD" carrying some 3000 lbs bombs.
The one thing both he and the other pilot he shared his "THUD" with said was it was a beautiful model but lacked one thing.  It was too clear.  Both stated that the F-105 was the dirtiest airplane either ever flew.  Oil, hydralic, and fuel leaks and spills coupled with wind blown sand and dirty and the residue of the black powder cartidge start system made the aircraft a mess.  That and being out in the SE Asia weather really dulled her down.
Again, GREAT MODEL OF A GREAT AIRPLANE!
Cheers,
leadsled757(aka thudfan!)
    May 2005
Posted by Bgrigg on Tuesday, July 4, 2006 11:43 AM
Well, you can disagree all you want. You've been judged by a jury of your peers! Big Smile [:D]
So long folks!
