Canopy
Canopy
Posted by Anonymous on Monday, August 25, 2003 8:22 PM
I saw it before but can't find the thread now but I spilled some thinner on a canopy and of course it looks ike crap. Was wondering what to do to fix it up. Thanks in advance.
T/A
Posted by Anonymous on Monday, August 25, 2003 9:13 PM
If the kit is still in production, you may want to contact the manufacturer. Many companies will send replacement parts.
If you don't want to wait, you may want to try a vacuum formed canopy from Squadron. A spare is included in many of these, in case of errors cuitting the canopy from the sheet.
I don't know if any sanding & polishing, followed by a Furure bath, would fix it.
You could also try the "plunge-mold" process, using a heated sheet of clear Theraform (0.006").
Good luck, & keep the thinner capped & out of reach when you're not using it !
Posted by Anonymous on Tuesday, August 26, 2003 2:35 AM
Thanks for the info Pixilater. Definitely keep the thinner out of the way the next time.
T/A
Posted by Anonymous on Tuesday, August 26, 2003 3:55 AM
Another method for polishing out errors inflicted on clear plastic is to start with fine emery paper or cloth used wet then come down in grit size rubbing in a different direction each time, do NOT use a circular motion, then use tooth powder as a finisher. Test the tooth powder on some scrap first. some tooth pastes will also work. The one I use comes from Ada mich. ( I dont like to advertise other peoples products)
Dai
Posted by gobears01 on Wednesday, August 27, 2003 1:01 AM
hey I just started to tear down a 20 year old Monogram F4U Corsair to see if could detail it up a bit.
The Canopy had a glue smudge on it since day one.
I experimented with Mcguires fine grit liquid auto polishing compound since thats what I had laying around.
It took that smudge out after three applications. Its clear enough to see the cockpit detail.
can you paint future on? I don't have an airbrush yet.
Matt
Offagain-Onagain
Posted by Anonymous on Wednesday, August 27, 2003 1:13 AM
Yes, you can paint Future. However, the best way to get an even coat is by dipping. If your Corsair is overall glossy Sea Blue, this shouldn't be a problem. If your frame on the canopy is not gloss, you can paint it.
