Junkers D.I - completed
Posted by djmodels1999 on Monday, September 1, 2003 3:50 PM
Thought I'd share with you a pic of a model I built a few years ago. It's this Junkers D.I all-metal fighter from the later part of WWI. The kit is a vacuform (Warbirds, for those who have heard of them!), at 1/72. Used some Tom's Modelworks PE bits for the wheels and the machine guns.
Hope you like it!
Posted by Anonymous on Monday, September 1, 2003 5:13 PM
Looks good.
    January 2003
Posted by Keyworth on Monday, September 1, 2003 5:35 PM
Sharp looking warbird. Thanks for sharing
"There's no problem that can't be solved with a suitable application of high explosives"
Posted by Anonymous on Monday, September 1, 2003 10:28 PM
Looks good, dj ! That must have been a difficult build - corrugated skin on a vac kit. How difficult was clean up on the leading edges ? And aligning the ridges & troughs ! Being 1/72, its gotta be TINY ! Really like those wheels - nice touch. Did you laminate a wooden prop ? It looks authentic if its just paint ! GOOD WORK !
Posted by djmodels1999 on Tuesday, September 2, 2003 2:01 AM
you are right, Pixilater, it was not the easiest of projects. I have to say that the kit had been well designed and that I actually had very little trouble aligning the ridges, even on the top of the fuselage. The trick was to get the trailing edges of the parts really thin enough... I only used 7 vacuformed parts: the fuselage halves, the radiator's front, the bottom part of the wings, the top parts of the wings and the stabiliser. The fin was scratch and so were countless little other bits in this model. The engine and its exhaust came from Aeroclub (white metal bits). The propeller was another Aeroclub item, and yes, it's just paint.
Posted by Anonymous on Tuesday, September 2, 2003 3:07 AM
Love the prop. I´ve got a 1:48 WWI plane waiting in the wings (no pun intended) which also needs an authentic wooden prop.. Howdya do it?
Posted by djmodels1999 on Tuesday, September 2, 2003 3:30 AM
Mmmm... Was a loooong time ago, you know..! Think I started with a 'sand' colour all over, then used a 'chocolate brown' and a fine brush to paint the 'stripes' from one tip to the other tip, making sure to go over the hub. Each 'stripe' will start on one side of one blade and end up on the opposite side of the opposite blade. Next, using a stiff flat brush I applied some darker brown. You just want to lightly 'streak' the 'sand' and the 'chocolate brown' so that only a few extremely thin darker lines appear, fairly randomly, but in the direction of the wood's grain, in a few locations. Next I painted over the propeller's manufacturer logos, then appled a couple of coats of Future to give the whole thing some shine...
