Decals For F-15A?
Decals For F-15A?
Posted by Anonymous on Friday, September 12, 2003 12:02 PM
There are lots of decals sets out there for F-15 C&E but I havent been able to find many specifically for an F-15 A. Thanks For Any Help
Posted by Anonymous on Friday, September 12, 2003 12:57 PM
Have you tryed checking out Super Scale? They have 1/72 sets that havs A's. Bob
Posted by Anonymous on Friday, September 12, 2003 4:29 PM
Hey Sam,
TwoBobs did a sheet of the 2 Massachusetts ANG A models that scrambled on 9/11/01... Not sure if they're sold out, but it would be worth looking into.
Brian
Posted by Anonymous on Friday, September 12, 2003 7:42 PM
A better question (since I have the two bobs set) is who makes a good F-15A kit? Hasegawa seems to only have the C and later. And for that matter, what's the difference between the A and C.
Posted by wroper11 on Friday, September 12, 2003 7:57 PM
If I am not mistaken the only difference between the two models is avionics packages. A's and C's are both single seat fighters. B's, D's and E's are dual seat. I was stationed at Langley and the 1st Fighter Wing had C models. They had A models first then upgraded.
USAF PRIME BEEF ENGINEERING READY...ANYTIME...ANYWHERE! HOORAH!</font id="blue">
Posted by Anonymous on Friday, September 12, 2003 9:49 PM
Hi There, Bare metal foils has a decal set for F-15A. It is the 318th FIS the green dragons . These F- 15A's were based at McChord AFB (Tacoma, WA) in the early 80's before the Squadron was Deactivated
    January 2003
Posted by markuz226 on Saturday, September 13, 2003 2:00 AM
Tamiya has a (relatively old) 1/48th F-15A and Academy has C/D version. Since I have these kits unbuilt, is there anybody out there who's got any comment on the above-mentioned kits? thank you very much.
Posted by Anonymous on Saturday, September 13, 2003 12:54 PM
There are some panel differances too and the main wheels are differant up til the 90'. The brake stack of the A &B is 1 disc less,the C &D areheavier due to larger fuel capacity. The comm panel on the C&D is closer to the left inlet and the chaff flare dispensers are just forward of the left & right main gear doors. Also if you want to depict an F15 after 1989 remove the tailhook cover between the engines. Bob
