100 million rpm is just too fast!!!
Posted by Anonymous on Saturday, September 13, 2003 5:23 PM
Well, it may not be that much; but my single speed dremel tool is not suitable for fine detail work. What do you guys use? I would like to find another moto-tool more practical for tight spaces and capable of slower, adjustable rev's. If you have a dremel type tool you can't model without, let me know what it is so I can start looking to upgrade. Thanks, Lenny.Big Smile [:D]
Posted by dogsbody on Saturday, September 13, 2003 6:17 PM
I have a single-speed Dremel connected to a Dremel speed controller. With this I can manually dial in the speed from 0 up to the max. of the tool. I don.t remember the price of the controller but it should't be to hard to find.
"What young man could possibly be bored
with a uniform to wear,
a fast aeroplane to fly,
and something to shoot at?"
Posted by ardy299 on Saturday, September 13, 2003 7:25 PM
Same here, Lenny. Find a speed controller, usually a store that carries Dremel can get one if they don't normally stock it. Or maybe one of the newer Dremel that has variable speed built in.
Bob
Posted by cnstrwkr on Saturday, September 13, 2003 8:10 PM
Lenny,
Dremel has a speed controller(#221) for single speed moto-tools. It will bring the speed from 0 rpm to whatever the max rpm is. It is a foot pedal design and is somewhere around $45.00US
Tommy difficult things take time...the impossible, a little longer!
Posted by dogsbody on Saturday, September 13, 2003 10:04 PM
My controller doesn't have the footpedal control, just a knob that you turn to change the speed. I think this version is a little cheaper.
Posted by Anonymous on Sunday, September 14, 2003 1:32 AM
Or you just control the voltage output if you have a variable transformer.
My tool work at 12V, but if i set it to 9,6,3,even 1,5 it will operate at different speeds. I bought the transformer for about 4$.
    July 2003
Posted by 72cuda on Sunday, September 14, 2003 8:14 AM
Hey LFirth;
what I've done for my Dremel is get a 2 outlet wall box, a varible light switch and a single std 3 pronge outlet, and a extension cord, and wired up an veriable adapter for the Dremel,
just cut the receptical off the extension cord thus leaving the male plug with the wire, then take the poled wire to the white side of the receptical and the none ploed wire to the black terminal on the light switch the have a jumper wire to go from the white terminal of the switch to the black terminal of the receptical then run the wire throught the box and mount the switch & receptical to the box and you could put a cover on the box to cover the faces of the sw & recpt. and wella you got yourself an inexpensive adapter that costed about $10.00 and work very well and you used your little ole hands to help your hobby along instead of paying over $30.00 for basically the same thing
Ugly Butt Deadly Effective Hawgs
cuda
84 of 795 1/72 Aircraft Competed for Lackland's Airman Heritage Museum
Was a Hawg Jet Fixer, now I'm a FRED Fixer
 'Cuda
Posted by Anonymous on Sunday, September 14, 2003 11:10 AM
YES IT IS.....
i joked on the calculation
100million/min around 1670000 rev /sec
axial speed at the edge of 1inch collet = 2*(pi)*R*radial speed
that amounts to almost 325 Mach.
Posted by Anonymous on Sunday, September 14, 2003 10:48 PM
Well, I use a variable speed dremel, but another tool that I find useful for tight corners and fine detail is a flexible shaft chucked into my variable speed hand drill. The drill is clamped to the end of the bench and set to run at whatever speed I want, and the flex shaft chucks into the drill. The end of the shaft fits in my hand and has a set of collets similar to the dremel. I often find it easier just to handle the shaft (much like a dentist handles their drill, it is the same sort of set up). I got my flex shaft from Lee Valley but I have seen them at large hardware and home depot type stores as well.
    July 2003
Posted by 72cuda on Monday, September 15, 2003 8:33 AM
Also if you like the Dentist drill noise then you too could own one, but the down fall is that they are pricy, from about $200.00 to $1k a piece, and they will run off your airbrush compressor too they only need 35psi to run at max rpms, and the bits are expensive too but you could do some ausome carving work with it though
Cuda
 'Cuda
