Future and Solvaset
Future and Solvaset
Posted by Bones-coa on Friday, September 26, 2003 10:46 PM
Guys, I have a dark painted model with a coat of future on it. I was putting decals on and the solvaset I use for the decals seems to be turning the aircraft finish white. In otherwords, it seems to be attacking the future. Is there something I'm doing wrong? Or will this clear up after I apply another coat of future over the decals? A little worried here.
Dana Disapprove [V]
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
Posted by Swanny on Friday, September 26, 2003 10:57 PM
Don't worry - everything will be okay. Let it dry, tomorrow recoat the offending areas with Future and the white will go away. It is a reaction between the Future and the Solvaset - in the future be sure to wick off excess setting solution to reduce these kinds of trouble.
Posted by Bones-coa on Friday, September 26, 2003 11:13 PM
Whew...thanks Swanny. I think i'm breathing again. Dead [xx(]
Posted by ardy299 on Saturday, September 27, 2003 8:07 PM
That's different, in a number of years of using future for a gloss coat and then decaling over it using mainly Superscale decals and Solvaset I've never had this happen. I do live in a very dry non humid area and wonder if this has something to do with it.
Bob
Posted by Swanny on Saturday, September 27, 2003 8:52 PM
Bob
Usually two factor lead to this kind of problem;
#1 not having let the Future cure completely which is why I reccomend waiting 24 to 48 hours between applying Future and decals and
#2 Letting a quantity of decal solvent sit on the surface which is why I suggest using a piece of tissue paper to wick off the excess. Most decal solvents will do this like Micro-Sol, Mr. Decal Softener and Solvaset.
If you are in an area with high humidity you must work on the high side of that time envelope.
