Decals
Decals
Posted by lpolpo22 on Monday, September 29, 2003 11:52 AM
When it comes to 1/72 and 1/48 aircraft which are the better decal companies and which should be avoided?
Posted by Butz on Monday, September 29, 2003 12:24 PM
Hey lpolpo,
I have used the following w/ awesome results:
Aero Master,Experts Choice,Eagle Strike,TwoBobs decals.
I have not really come across a company that I would totally avoid(knocking on wood)Tongue [:P].
Lets see what some of the other fellow builders have to say.
Flaps up, Mike
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
Posted by Anonymous on Tuesday, September 30, 2003 4:08 AM
I tend to agree with Butz; I've also used the same decals as he has with excellent results. Actually, the only decal sheets I've ever run into troubles with have been those which came with the kit, e.g. Revell or Monogram.
However, every time I get a sheet from an outfit I've not used before my tendency is to be a tad cautious. For example, the first decal I start with is one which can be replaced, such as a national insignia, and not one of a kind. Each after the market decal company seems to have different soaking times and ease of applying. Also, they respond differently to decal setting solutions. I'm very, very careful when applying Micro Sol to an unknown decal and thin it with a bit of water until I know how it is going to react.
    August 2003
Posted by mtollens on Tuesday, September 30, 2003 7:46 PM
Kit decals are usually the ones to fall apart; why don't they have a company like Superscale/MIcroscale do them instead? I just used a 2Bobs set and they went down easy with Micro Sol/Micro Set.
Max Tollens "plastic surgeon"
