decals application and weathering
Posted by Anonymous on Sunday, October 26, 2003 2:51 PM
Smile [:)] hi everybody is there anyone that can answer a query about decals do you weather before apply or after for best results any info would be very welcome Question [?]
Posted by Anonymous on Sunday, October 26, 2003 3:05 PM
I don't know for sure, but I think you're supposed to wait till after you put on decals to weather. After all, on a real aircraft, the weathering occurs after the marking/insigna are painted!Big Smile [:D] Also, if you're doing a wash, then you don't want a decal covering that; you want the wash over the decal. Hope I helped a little!Smile [:)]
Posted by BlackWolf3945 on Sunday, October 26, 2003 4:01 PM
Depends on what techniques you may be using. There are some, such as pre-shading, which you want to do before the decals go on. Matter of fact it's done before the paint's put on. (Pre-shading is highlighting the panel lines and any other desirable areas with black or some dark color which will stand out when the paintjob is applied)
As to washes and pastels and all, most folks who weather their models do all this at the very end after everything else is completed on the model.
I tend to mix it up a bit; in areas where there's no markings I'll do a little bit of something before I put the gloss on for the decals. Then I'll do some while the gloss is on, both before and after applying the decals and a secondary gloss coat to seal them. Then I'll do some more after that secondary coat of gloss is applied and, finally, I'll finish up after the final clear is applied.
What this does is to change the tone and/or value of the colors I apply as weathering. Each successive application of clear will alter the appearance of whatever colors are below it, including washes, pastels etc. This is just my own technique, based on my observations of the real deal, my interpretations of those observations and, most importantly, my personal preference.
My advice is to try a buncha different techniques and ways to apply those techniques and see what works for you. Ultimately it comes down to what you like.
Fade to Black...
Posted by Swanny on Sunday, October 26, 2003 4:21 PM
read this....
http://www.swannysmodels.com/Weathering.html
