Sort of a noob question...
Posted by Anonymous on Monday, November 10, 2003 6:41 AM
I am working on only my 2nd aircraft and have a question:
Do you paint the interior of the landing gear bays before or after exterior painting is complete? I paint the cockpit details before both halves of the fusalage are combined and insert tissue before painting.
Just wondering what would be the easiest way to go about this.
PS...I am working on Tamiya's ME262-A2a
Posted by djmodels1999 on Monday, November 10, 2003 7:12 AM
It's sometimes easier to paint the before, particuarly if there are 'hidden' recesses or if they are deep, but of course, some masking will be necessary if you use an airbrush to apply the camouflage color. Any corrections can then be made with a brush.
For the cockpit details, I always paint before closing the fuselage, but in some cases, I'll leave seat, sight, other details off until after final painting (to make masking easier).
Posted by Anonymous on Monday, November 10, 2003 8:56 AM
If you're painting the gear wells aluminum, take care masking them. Many metallics are very fragile (sush as M M Metalizer) If you have a scanner, scan the lower wings where the wheel wells are, and print it on heavyweight paper. Cut out the well openings & presto ! Instant masks.
Posted by djmodels1999 on Monday, November 10, 2003 9:11 AM
Hey, cool tip, Pixilater... Never ever thought of that! Thanks!
Posted by Anonymous on Monday, November 10, 2003 9:30 AM
Or you could mask the wheel well form using the silly putty after the painting. I use it and its perfect.My 2 cents [2c]
Posted by Anonymous on Tuesday, November 11, 2003 1:42 AM
usually you should paint before. but if the wells are crude or shallow it is not difficult to paint after....flexibility is a good thing. Why call for the keyman to open the door for you when the window next to it is open?....
