Hairspray technique?
    December 2008
Posted by Byrne0ut on Thursday, January 15, 2009 7:18 PM
Can somebody explain this to me, Me no get it...
ON The Bench: Tristar 1/35 Panzer 38(t) Ausf. B Glencoe 1/400 SS United States Tamiya 1/35 Panther Ausf. A Early On The Shelf Tamiya 1/35 King Tiger Tamiya 1/48 F4U-1D Corsair
    January 2007
Posted by dahut on Thursday, January 15, 2009 7:38 PM
Me too. Well, me niether..... neither.........
Well, you get the idea!
Cheers, David
    April 2014
Posted by Carves on Thursday, January 15, 2009 7:57 PM
Basically it is for whitewash camo. The hairspray method was use to simulate a worn out whitewash camo.
In a rough step this is how it is done;
- Spray base color (ie. green)
- Spray hairspray
- Spray white color
- Bath the model into warm water and use a stiff brush to loosen up the white paint.
Note: effect and result may vary.
    December 2008
Posted by Byrne0ut on Thursday, January 15, 2009 8:00 PM
u know what i did, i painted the base coat, they I put a whitewash on with acrylic craft paint.  After that dried and sprayed some dull coat, and the dull coat actually kinda faded the whitewash in random places so the cammo pattern underneath was about to show through, when I do an oil wash on top I have a feeling it will look really good.
    January 2007
Posted by the doog on Thursday, January 15, 2009 8:07 PM
OK< here we go..sigh--I had to delete this when I sold the article to FSM, but here's a condensed version...here's the "Lair of the Rust Bunnies" article I did that was published in the November 2008 issue--it's still available in back issues.
You spray your base coat--in this case I wanted a rust color underneath...I was using Tamiya acrylic in this case. I have seen this technique done with either enamel or acrylic base coat; as far as I know, I was one ofthe first to tryit with acrylics--I would recommend Tamiya since they are a pretty durable, tough acrylic coat.
Then you get some hair spray
Spray the whole model with it---one coat is all you need. The tape is there to allow some "breaks" in the paint coverage--you need them in order to let the water you're use to dissolve the next coat on top. ALthough, at this point, I have learned that you can simply scratch the paint with a blade, or sandpaper, and still get the water to go underneath the 2nd coat and start dissolving the hair spray, which then dissolves and fractures,carrrying away with it the paint coat on top of it.
Here, I've sprayed the color coat--in the case of a whitewashed tank, this would be your "Whitewash" coat.
In as long as it took me to clean the airbrush, I take a short-bristled, stiff brush, and after dipping it in water, start scrubbing away the paint. The hairspray underneath dissolves, leading to a greatly distressed look as it carries away the paint as well.
It's very easy to control--dab off the excess "dead" paint with a facial tissue
What it will look like
Here's a few pics of what you can do with proper weathering using pastels and powders, and the hairspray technique.
I also used it on a whitewashed King Tiger here--it's on this page; you can see the results of it before I started weathering the tank in earnest.
Here's the link to that page...
/forums/2/1053435/ShowPost.aspx#1053435
    December 2008
Posted by Byrne0ut on Thursday, January 15, 2009 8:12 PM
ur the man doog.  How does FSM pay for their articles?
    January 2007
Posted by the doog on Thursday, January 15, 2009 8:18 PM
A million dollars a piece! It's a pretty fair price....Wink [;)]
    January 2007
Posted by dahut on Thursday, January 15, 2009 9:09 PM
You rule, Karl. Good to see you.
Thanks.
Cheers, David
    December 2008
Posted by Byrne0ut on Thursday, January 15, 2009 9:10 PM
A million dollars a piece! It's a pretty fair price....Wink <img src=" border="0" />
 Wouldn't that be nice, I dont think FSM's subscribers list is quite large enough to facilitate that.  But i really appreciate the response and I cant wait to give it a try.
    April 2008
Posted by smeagol the vile on Thursday, January 15, 2009 9:18 PM
so THAT was my issue.  I didnt put the tape down, I figured the water would get under from the edge.  Thanks for clarifying that Karl my man, Im gona try that tomarrow after my midi ensemble
    April 2014
Posted by Carves on Thursday, January 15, 2009 10:51 PM
You know what ? I wish that excellent article(s) like this can be made sticky  Boohoo [BH]
Admin ? Knock knock knock on admin's door Whistling [:-^]
    June 2008
Posted by Hans von Hammer on Thursday, January 15, 2009 11:05 PM
It's on the site... You might have to be a subscriber to see it though....
http://www.finescale.com/fsm/default.aspx?c=a&id=3208
