Academy 1/25 Panther G Late Version WIP COMPLETED!!!!
    November 2008
Posted by plasticjunkie on Thursday, May 16, 2013 8:03 AM
I bought this from from Squadron back in 2003 when it first came out. I will be using Aber pe, and Tamiya link track. I will be using the Tankograd In -Detail Panther and Jagdpanther book which has TONS of color photographs taken at different angles of both the Panther and Jagdpanther. I took all the road wheels off their trees and cleaned them, storing them in small plastic containers. The turret was next. The back plate was glued on but it had a nasty gap at the bottom and smaller gaps at the sides. I used plastic card to make up for the gap area and thick ca for the thinner side gaps. The barrel halves were glued together and produced smooth seams that were easily sanded away when fully cured requiring no filler. I used Mr. Surfacer 500 stippled on the commander's cuppola, fresh air vent cover and gun mantlet to enhance the cast texture. The included plastic lift rings were too thin so I bent my own from my assorted collection of electronic wires I have and super glued them to the roof. I also added some cast numbers to the mantlet barrel ring that I shaved off from left over sprues.
Gap on turret bottom rear
Another view of the gap
Card stock in place
Problem solved
I also added the three hex bolts to the turret top along with the Osterkompass mounting tab that I bent from a left over piece of PE fret. All were secured with thick ca.
Comments and critiques are welcomed.
 GIFMaker.org_jy_Ayj_O
Posted by tigerman on Thursday, May 16, 2013 10:42 AM
Off to a good start. Are you going to be doing your own zimmerit or AM?
 Eric
    September 2005
Posted by Sprue-ce Goose on Thursday, May 16, 2013 11:14 AM
Nice!
I have a 1/25 Tamiya Panther Va purchased second hand from a LHS and have noticed the drive gear sprocket teeth are spaced further apart compared to those of the Academy kits.
How do you intend to fit the Tamiya track links to the Academy kit?
BTW.....I notice the Tamiya website is still selling Panther track link sets if you need spares.
    November 2008
Posted by plasticjunkie on Thursday, May 16, 2013 12:25 PM
Tigerman
No zimm on this kitty which will be late 44 with disc cammo. There are no reverse circle stencils for this scale so I have to make my own. I have a pretty good idea on this so hopefully it will work out.
Goose
The Tamiya tracks do not fit on the Academy sprockets so I have two options. Either contact Tamiya about their Jadgpanther tracks or slice off the teeth so the tracks can properly sit, then glue back the teeth into the track slots or cover the slots with terrain debris. I'm still working on that department.
    October 2004
Posted by PITERPANZER on Thursday, May 16, 2013 4:14 PM
I`m so happy to see next 1-25 scale model.
You are Yoker, because after few Year I have got ,realy some PE kits to panther G.
 If somebody remember I used this 3 kits to my panther G. Now, it `s a llittle different base kit ,rescaled from PE dedicated to Dragon. i have to test MG34 ,tank version barrels too.
More in Panzer Hobby Art shop ;-)
I will follow Your relation every day .Good Luck
    July 2004
Posted by wbill76 on Saturday, May 18, 2013 5:47 PM
Off to a good start! Will be watching with interest. Yes
    November 2008
Posted by plasticjunkie on Saturday, May 18, 2013 11:21 PM
Piter and Bill...Thanks for your interest!
Was able to work a little today. Replaced the molded stowage box latches with the Aber ones.
Molded details
The Aber details are really nice but hard to work with even at this larger scale.
I removed all the molded details from the mudguard and the Bosch headlight and replaced them with the Aber set. The wire came from my collection of discarded electrical wires. Notice the two tiny wire clips. I added a clear plastic piece that looks like a lightbulb then used 5 minute epoxy to lock it in place and to act as glass. The headlight cover hides these details but a modeling judge with one of those tiny flashlights will be able to see something thru the slit.
Made my own spade handle from stretched sprue and used the Aber parts. A HUGE improvement over the Academy spade.
    September 2005
Posted by Sprue-ce Goose on Sunday, May 19, 2013 9:07 AM
Looking very nice ! Big SmileYes
I haven't seen the Aber stowage bin latches assembled on a kit.
Do you have a PE bender or did you improvise?
 One side note; it is fortunate you were able to obtain Mr. Surfacer.
The product is unavailable in Chicago area hobby shops.Crying
    November 2008
Posted by plasticjunkie on Sunday, May 19, 2013 1:15 PM
Thanks Goose... I got my Mr Surfacer 1000 and 500 from Sprue Bros a while back and this stuff is a life saver. I improvise my pe bending by using an old bathroom tile as a cutting surface, Xacto blades for cutting and two single edge blades for bending, it works great. You would think the molded details are better in this larger scale but not really. They could have done a much better job with the clamps, tools, tracks and at least a partial interior in the turret. At least it has all the periscopes so it's one less thing I don't have to scratch out. Geeked  I remember the huge hype when it was on a pre-order status back in 2003 prompting me to jump on the bandwagon.  I wanted to keep this a basic and simple build but it has been gathering improvements here and there as I go. I started scratchbuilding my own fire extinguisher since the molded one doesn't look anything like the real one.  Been working with some of the pe too so I will have more updates soon.
    January 2007
Posted by the doog on Sunday, May 19, 2013 3:26 PM
Man, that's some cleeeean building going on! Lookin' VERY good!
Posted by Texgunner on Monday, May 20, 2013 1:22 PM
Ernie, loving those added details!  Great start on that project bro'.
Gary
"All you mugs need to get busy building, and post pics!"
    May 2004
Posted by f8sader on Monday, May 20, 2013 2:46 PM
Nice work plastic!
Lon-ski
    November 2008
Posted by plasticjunkie on Monday, May 20, 2013 3:37 PM
Doog, Tex and f8..........Glad you like this wip!
Was hoping to keep this a simple build but it screams for little tid bits here and there.
Did some work on the tools by getting rid of all the molded latch details, mounting tabs and thinning down some parts to make them more scale like. Sink marks were filled in with Squadron putty then sanded smooth.
I added theAber pe parts to the handle mechanism, cut off the plastic mounting tab and sliced off a molded grab handle which was located too low and replaced it with a thin wire bent to the correct shape.
The top is my scratched out fire extinguisher made from a computer electronic part, stretched sprue and Aber pe part. Network 54 has several pictures of German WWII fire extinguishers so I modeled mine as such.  Looks a lot better than the Academy one.
Top is the Academy spade. Bottom is my scratched built one with stretched sprue and Aber parts.
Complete group ready for painting. the Tow hook lugs are drilled to accept the safety pins that I still have to make out of wire. Notice the nice multi-part Aber fire extinguisher holder.
The jack mounting slit was located too low so it was filled in with plastic stock and Squadron putty, then sanded smooth. The jack is vertically suspended a bit higher as per the Tankograd photographs. I still have to assemble and attach the Aber jack mount.
    September 2006
Posted by RBaer on Tuesday, May 21, 2013 10:47 AM
Nice work.
Apprentice rivet counter.
    July 2004
Posted by wbill76 on Tuesday, May 21, 2013 5:38 PM
Nice job dressing up the tools and other little details. Beer
    November 2008
Posted by plasticjunkie on Sunday, May 26, 2013 7:12 AM
RBaer and Bill.........Thanks for your comments!
Been very busy and unable to put some serious bench time in but managed to do a few things.
At this larger scale, it's wise to put something on the inside of the louvers so it doesn't look hollow even though the details will be barely visible thru the grills and screens. I save those plastic cards that come in the junk mail and use them to manufacture scratch built details. Using my Micro Mark mini punch and a larger one from Harbor Freight, I punched out a series of discs to make the fan units and bolts. I also sliced up strips to make the four air vent slat boxes.
The Aber jack mount was built per the instructions with working hinges. I made the hinge pins from stretched sprue. The jack rested on an L shaped metal bracket that I bent out of a left over piece of pe. The circular hatch area was also detailed by replacing the molded manual starter crank with stretched sprue and separating the brackets. I still have to attach the small chains that secured the crank to the brackets.
Here are the completed fans painted in alumunum and boxes painted in my own mix of primer red craft acrylics
Drilled out the small circular molded screen on the rear deck and replaced it with the Aber screen. The cross guard detail was added from thin Evergreen strip to the scoop front.
    November 2008
Posted by plasticjunkie on Saturday, June 1, 2013 12:16 AM
Posted by Texgunner on Friday, June 7, 2013 1:23 PM
Damned nice work Ernie!   You're making me eye that M41 in my stash...might be a cool diversion for this summer-build another tank!  Keep up the inspiring good work!
Gary
    January 2006
Posted by SprueOne on Friday, June 7, 2013 10:36 PM
Fantastic progress in 1/25
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
Posted by tigerman on Saturday, June 8, 2013 12:37 AM
Appreciate the fine work.
 Eric
    January 2007
Posted by the doog on Sunday, June 9, 2013 8:40 PM
This has gone beyond a mere "build": it's officially a "Labor of Love". Big Smile
    October 2004
Posted by PITERPANZER on Monday, June 10, 2013 11:16 AM
All look very good. Maybe this relation and later gallery will helpfull for  You with camo.
Good luck and wait for the Your gallery.
    November 2008
Posted by plasticjunkie on Tuesday, June 11, 2013 1:15 PM
Doog... You are right Sir. Even after thinking of nothing else to add, something pops out at me. I even thought about scratching out the turret interior to leave both hatches open but I did not want to get into a complex build. Hmm
Piterpanzer...Thanks for your links. They come in very handy.
I'm at the painting stage now so I will have an update soon. Thought I had the brown cammo paint but looks like a trip to the Hobby Shop.Big Smile
    November 2008
Posted by plasticjunkie on Thursday, June 13, 2013 10:57 AM
I almost forgot to scratch out the jack wood block and mount.
using the kit's plastic part as a template, I traced the dimensions on a piece of scrap wood and milled it out on my table saw.
I used a piece of scrap pe and some plastic stock to make the jack wood block mount.
Perfect fit. I will stain and weather the wood block later.
Next task was to spray the big cat and the running gear.
Using a circle template, all wheels were sprayed MM Dunkelgelb along with the sprockets. I was lucky to get the sprockets from a friend who had a junked Tamiya Jagdpanther so the tracks have a perfect fit now. The tracks were prayed with black Rustolium, then craft acrylics were thinned and mixed to get a brown rust shade and were sprayed thru my ab.
The three tone cammo was sprayed using MM Dunkelgelb, Panzer Olivgrun and Vallejo Panzer Series Cammo Brown.
My next task was the 'Disc' scheme. I have two choices, make a bunch of circles on a piece of tape then cut the areas between the circles Indifferent or use a bunch of round stickers. Both methods are time consuming but the sticker route seemed to be a bit easier. I purchased a couple of different sized sticker packs from the craft store for a couple of bucks each and started masking.
No it's not groovy art from the 60's  but it should work.
All stickers removed. Looks like  it worked!
I think it looks pretty close to the real thing. The coaxial MG was not included in the kit so I used a thin piece of brass pipe as the MG's muzzle peeking just a bit in the  mantlet.
Another view of the turret. Next in order will be the hull Disc masking then the real fun part, decaling and weathering.
    January 2010
Posted by Shawn M. on Thursday, June 13, 2013 3:28 PM
love the disc camo, great method to boot!
I love the smell of plastic in the morning
    November 2008
Posted by plasticjunkie on Friday, June 14, 2013 10:07 PM
Thanks Shawn, glad you like it. I think it's quite different from the usual camo schemes.
Added the stickers to create the pattern.
Rear view
With the stickers removed, the pattern becomes visible
Rear view. This part was really difficult to mask as the stickers would not stay secured for long on the curved pieces.
Rear deck view, another difficult area to mask.
On deck for decals, filters, washes and more weathering
    October 2010
Posted by Dogfish_7 on Saturday, June 15, 2013 6:44 AM
Very labor intensive, but man, what a great look!
Bruce
    September 2006
Posted by RBaer on Wednesday, June 26, 2013 4:26 PM
Congrats on the Gold, well-deserved.
I have to say, I like the AMPS method as well.
