Tank Trakz
Tank Trakz
Posted by Anonymous on Wednesday, November 12, 2003 8:04 PM
I am drawing a blank when i am shopping for armor kitsSad [:(]. What are "link-and-length" tracksQuestion [?]
Posted by Anonymous on Wednesday, November 12, 2003 8:48 PM
Link and length tracks usually come with the kit, not as an after market part.
The name is exactly what you get.......links, a series of individual track links that you glue together (to go around idler wheels/Drive sprockets, etc) and length, a strip of links moulded as one kit part for the straight parts of the track that are glued together and to the individual link assemblies - Ie, under the roadwheels against the ground, on top between any guide wheels (like on Sherman tracks which are highly tensioned, not like on a Panzer IV which are looser and hang in curves between guide wheels).
The old Tamiya SdKfz 250 and the Italerie M113 with the vulcan cannon kits have these type of tracks.
Posted by Anonymous on Wednesday, November 12, 2003 9:43 PM
thanks. i have a mostly unbuilt Revell of Germany M2A2 bradley with these kinds of tracks and i didnt even know it! Now any idea what is the best way to paint a model with these kinds of tracks?
Posted by Anonymous on Wednesday, November 12, 2003 10:04 PM
Everyone does them differently, paint on the kit when glued or paint off the kit then glue on the painted kit.
Generally it would depend on the kit. The Bradley you are doing has side skirts. Are you going to fix them before painting? If so the tracks will need to go on firstTongue [:P]
What I have done to the kits I have, is prepare the tracks in two halves, an upper and lower run, then paint each half separately from the hull, then fix them in place before weathering. Firstly make sure that you have enough room to remove the track if the wheels are glued down. If not, use a bit of blu-tack to hold the wheels in place whilst you prepare the tracks.
Doing one run at a time, glue the top links and lengths together as per the instructions so that the ends would be half way around the idler and Drive sprockets -make sure the edge is in a straight line by placing the links against a ruler or something with a straight edge as you glue them together.
Let the glue set a bit then place them in position and gently push the links around the idler and sprocket but don't glue them to the kit. Let this set completly and if loose on the kit then use a little blu-tack to hold it in place. Then do the same procedure for the lower section making sure that the loose end links fit in the upper row links at the proper angle but don't glue them together yet.
When completely set you should be able to lift the track off the idler and forward off the drive sprocket for painting. Finally Glue them back on the kit when the rest of the model has been painted - don't use the poly cement as it won't join through paint, use cyano instead. Glue the track onto the road wheels and return rollers for added strength.
Hope this helps
Posted by Anonymous on Thursday, November 13, 2003 4:11 PM
thanks that really helps. I had no idea that i could just glue the tracks together off of the model. In the instructions it has you glue each link directly to the wheels, drive sprocket, idlers, etc., not to each other. oh well, now that i think about it is a fairly simple process. thanks again.
