Construction review of DPM new 1/72 Elephant.
Well i finishe building this guy, and she looks very nice. I really can see a photoetched kit for this little guy not far in the future. Construction was pretty strait forward, with a few gliches. Running gear was no problem, assembling nicely as do the running boards. The rear deck of th echassis is where there is lots of holes, and the instructions are not very clear. Building this again i will just putty this smooth and mount the parts that way. WOuld look a lot better. But since very little of this detail is seen, it is not a huge problem. You could install a piece of micro screen for the rear aircleaner. But again since it is not visable, you could just say why bother. (But what fun is that
) THe travel lock is very nice, but very delicate, be careful here. THe front vertical plate has two notches that need to be filled, do this before you assemble this area. Also there is another hole to be filled on the horizonal front plate in front of the drivers hatch. I also sanded smooth the junction betweent the upper superstructure, and the engine deck. This made for a much better joint. Also i put a piece of scratch plastic sheet under the main engine grill to prevent "see thru".
Aside from that it builds up very nicly, with very high quality casting all the way thru. Flash was almost noexsistent, and so were seams. THis is a great kit and i can't wait to build more of this series.
Bill
