Thanks again for the comments. It is well appreciated
Caveman - Thanks. (got the barrel right) I used Tamiya xf-61 dark green w/light buff drybrush - tracks are Dragon individual limks (painted tamiya dark earth) - comes in most Dragon kits. They're work to put together but I think well worth the effort - detail and ability to do track sag are great. No PE or aftermarket - straight out of box.
Erock - Thanks. I painted the whole thing (not the tracks) flat black - used testor's flat black in a can. I found their spray from a can really adheres to plastic. Anything that is bare, I brush flat black into the tight spots. Then airbrushed the green onto the high spots - leaving the black in the low and recessed areas. (more shadow) I use dark brown as a primer when I use any dark yellow paint scheme. I found the yellow doesn't cover as well and shows as a different color over black
Ron P - Thanks. No stretched sprues used in this kit either
Sherm - Thanks for the comments and the notice on the pics. I switched it as soon as I could. That Ron USMC is just too darn efficent.
Petbats - you're right - composition is everything
Thanks again guys. I've picked up alot of stuff hanging out here. You're comments are allways appreciated.
