The MLRS isn't too bad. Has some errors though. The rectangles on the side doors are thick, armored windows. They should have glass with a greenish tint to them. The struts holding up the LLM (Loader-Launcher Module, box on back) should not be there. They are only installed for maintenance or if the vehicle is on display. Also, the LLM will not raise if the launch pod container is not locked inside and the doors (pieces sticking up) are not in the down and closed position. When the launch pod is in, the doors will always be in the down position. The PE door covers look like they are missing the bulk on their sides too. They are too thin, the kit ones represent them well. The mirrors are on wrong as well, they should be switched around so they stick out, not up. The track is too loose; on the right side with it floating over the idler wheel; on the left, it is floating around the sprocket. He needs to remove a link or two per side.
The V-150 has some big seems on the tires. Otherwise, it looks pretty good.
Gino P. Quintiliani - Field Artillery - The KING of BATTLE!!!
