psstoff995 wrote: |
No need for an apology at all, on my part it was more lack of knowledge about the subject than anything you might have done wrong. I’m sure if I knew the differences between the M2 and M3A3s I would have quickly I-Ded it as a conversion project as Gino did. If you’re not too pressed for time could you let us know what you’re using reference wise? Also, it looks like you’re scratching with sheet styrene- but you’re managing to save/add the rivet detail, are those after market rivets? Or also scratched? Sorry I can’t really tell all your after market products from the pictures. Great work, with all the putty and scratch work so far, it looks like you’re really taking the time- the whole interior from the ground up is amazing! Did you curl flat styrene into the tube shape of the turret interior or was this preformed? |
Ok psstoff995 where to start where to start? Ok first I need to give credit where credit is due to HeavyArty for giving me that right kick in the addnodes that gave me the drive to build my and that's this build one more time., to make up for all my goofs on the first one. Ok with that said the next credit is due to the ((Amazing)) scratchbuilder Mr. Kim Hyoung-Min AKA khm1best for his help in what and where to place parts and all his scratch-photos.
Now on to all the rivits and bolt heads. I use Laytex rubber over othere armor models so I can make as mini bolt/rivits as I need. Now for the realy small ones I just use thinly pulled sprue and new sharp blade.
Now as for reference photos I have bean giving a lot of photos once guys have seen that I realy want to do the best version of this particular Bradley. So if you need some photos and info on the differences between the M2 and the M3 bradley variants. You can start here: http://en.wikipedia.org/wiki/M2/M3_Bradley_Fighting_Vehicle
One thing I have noticed in conveting my M2 is there as armor plates added and some new items added. I'll start posting some of my ref. photos and if you ask HeavyArty he can point you in the right direction. He also can tell you what parts and items are called and if he want's to he'll tell you what there used for.
Now your answer to and I quote: Did you curl flat styrene into the tube shape of the turret interior or was this preformed? Yes as I look at PVC and it was to thick to use so I did what I always do, I did it all my self. Next I'll post some of my old progress photos, way back to the start.
