Well, I got ther tracks installed on this Bad Boy, and they are looking pretty good. Here are a couple shots of the tracks.
This brings me to the reason I lke ACE kits: After getting all the tracks on, I find that I have plenty of additional 'tweezerpult ammo'!
As you can see above, with these kits a few track links can go flying, and you can let them lay wherever they land and get a new one!
After letting everything dry overnight, I put together the top and bottom hulls. You'll need to clamp the nose to get it to glue properly, otherwise there'll be a gap. Also, there was a gap between the back panel of the lower hull and the top hull, but it was easier to fix with a gap-filling CA glue and sanding.
Then I test fit the turret. It went on great!
Now she's starting to look like something!
The next day after that, I painted it with it's basecoat. That's when it really starts looking good! Made all the earlier hassles worth it!
Here it is ready to be detailed:
I hope you like these pics. It feels good to finally be through this tough build! I also apologize for those with slow systems and dialup modems. I tried to set the pics to be small as possible without compromising the detail I wanted you to see.
Bottom line: Some of the wheels aren't exactly in the right place, and the tracks are higher on one side than the other, but I'm quite proud of the work I've done. Besides, it's Iraqi! By this time, every one of the 1:1 scale Enigmas are sporting a smoke and rust style camouflage pattern!
