Individual Track Links
Posted by Anonymous on Thursday, January 1, 2004 6:32 PM
I am new to armor modelling. How do you assemble individual track links?
Thanks Everyone!
Posted by Anonymous on Thursday, January 1, 2004 6:40 PM
hello and welcome to the forums. it kinda depends on the manufacturer , some you have to glue together , some you have to drill and put wires/pins in the holes. what kind tracks are you having a problem with?
    December 2003
Posted by spector822002 on Thursday, January 1, 2004 6:40 PM
What kind of tracks are they ? ... Plastic stock ? metal ? resin ? get back to me and I will try to help !Smile [:)]
    January 2003
Posted by shermanfreak on Thursday, January 1, 2004 7:01 PM
Welcome to FSM allisonsarah. Good to have you join us here in the Armour Forum.
To add to the questions the others have all ready thrown back at you ... what will they be going onto. There's a big difference between Tiger tracks and Sherman tracks, even though they may be both indy tracks.
    December 2003
Posted by spector822002 on Thursday, January 1, 2004 7:11 PM
I agree with that sherman .... tanks from the U.S.A. usually have tracks so tight you have to wonder how they last. Wheras german armour is much looser like a tractor ... then there is russian ... where you have to wonder how they even stay on while driving !
Posted by Anonymous on Thursday, January 1, 2004 7:19 PM
Ha ha... shermanfreak couldn't chime in without givin a "sherman" as an example... Tongue [:P]
Allisonsarah... yep be more specific please... Smile,Wink, & Grin [swg] oh yeah.. and welcome to our world!
PS Shermanfreak... I still haven't forgotten about those tracks.. bear with me..Big Smile [:D]
    April 2014
Posted by r13b20 on Thursday, January 1, 2004 8:26 PM
Welcome allisonsarah! I'll watch this thread if I ever run into indy tracks myself!
Posted by Anonymous on Thursday, January 1, 2004 9:01 PM
My problem is with Dragons Elephant plastic links. Can’t keep em streight and how do I wrap them around without falling apart?
Posted by tigerman on Thursday, January 1, 2004 9:15 PM
Welcome allisonsarah. I have the kit, but have not started it yet. I have heard that the tracks are inaccurate. Most people use a jerry rigged jig to align them straight. For keeping them together I use a slower curring glue and make a set of tracks. After they harden a bit, I shape them around the drive sprocket and glue them down. Then make a long run of them and attach them from the sprocket towards the idler. Now the Elefant will have some sag just after the sprocket. Continue around the idler and towards the sprocket. Good luck, hope I didn't confuse you.
 Eric
Posted by Rob Gronovius on Thursday, January 1, 2004 11:14 PM
I line them up on a piece of wide masking tape using a 6" steel ruler to keep them straight.
Once I've got the length I want, I put a drop of glue at the connection points. If the run of track sections is going to curve around the sprocket or idler, I curl the tape with tracks still on around that piece. For a top run that will sag, I stick a paint brush or pencil under the tape so the tracks will dry in the proper wavy position.
I usually make four runs, one for the bottom, one for the top and one each for the wrap around the sprocket and idler.
    July 2003
Posted by nmayhew on Friday, January 2, 2004 4:11 AM
allisonsarah hi!
welcome to the forums!Big Smile [:D] Sign - Welcome [#welcome]
my initial advice would have been to take your kit and tracks into a sound-proofed room and prepare to start swearing...a lot!![:0]Angry [:(!]Disapprove [V]
they are a huge pain in the behind Banged Head [banghead], BUT you can get a much more realistic effect with themBig Smile [:D]...if you want to steer clear of them, buy a tamiya kit (i'd say); dragon models all have them that i've seen....err, preparing to be corrected no doubt!!Whistling [:-^]
Rob Gronovius thanks for the advice re the tape...never would have thought of that...i'll give it a go for the sherman group build (not looking forward to those tracks at all Sigh [sigh].
anyway, hope you get your tracks sorted alisonsarah....
regards,
nick
Kind regards, Nicholas
Posted by mark956 on Friday, January 2, 2004 9:38 AM
Welcome to the FSM forums allisonsarah. The information Rob Gronovius has given is very good, it should help straighten out your tracks. Good luck on your model. Posting some pictures of your model would be great.
mark956
Posted by Anonymous on Friday, January 2, 2004 11:06 AM
I too have to say thanks for the info. I have an Academy FISTV. When I had complained about constructing these treads, it had been suggested that I get a set of aftermarket treads, but I like the tape idea.
Posted by Anonymous on Friday, January 2, 2004 11:45 AM
welcome to the forum sarah,i am rather new here myself ,,but the pple here are grt8 and very helpful,,,,,,,,keep up on the building
Posted by RAF120 on Friday, January 2, 2004 9:42 PM
I did individual track links once before on one of Dragons Panzer IV. I learned how to do it from our very own FineScale Modeler. In the May 99 issue there was an artical by Joe Morgan called "Getting started with Individual-link tracks". I followed what he said and they came out fine.
In a nutshell he says to work on one side at a time, work in short runs using the tops of the road wheels as stepping stones, use liquid cement to join the links and use super glue to attach to the road wheels.
Trevor Where am I going and why am I in this handbasket?
Posted by Anonymous on Saturday, January 3, 2004 10:39 AM
Thanks to all. I will try all the suggestions and try to be patient.
Allisonsarah
Posted by Anonymous on Saturday, January 3, 2004 11:11 AM
Welcome to the forum allisonsarah. I too was pondering on this subject since I have not encountered building indy tracks before. Thanks for the people here & for the Major on the quick refresher. Now I could start with my Dragon M1A1HA.Big Smile [:D]
