I use the base color of the vehicle and then hit it with a dark wash. Starting with brown I stipple the surface. Then use a lighter stipple to give it a variated look. Like leopopld I'll then use a light orange to drybrush the highlights. I'll then take orange pastels and put a heavy coat of pastel dust on it, with some brown. This gives it that powder rust coat look. A little black or dark brown pastel along seam lines or edges and then once over with some graphite on hard edges and it makes for a pretty good looking rust job.
Overspray is just that. Think of overspray as any surface behind the object you are targeting. The "over" spray is all the extra that went past your target item. It gives a light dusting to that surface because the particles or micro droplets of paint are further away from each other in the spray cone. If you looked at it up close it would look like dust on a surface. It is because of this that the eye is fooled into thinking that the surface looks lighter.
Back the airbrush away and "mist" the area. (Obviously this must be done before attaching the muffler or exhaust to the vehicle). You can make some nice weathering highlights with this too by using a slightly lighter shade of base paint and overspraying the upper surfaces. Makes for a nice sun fade.
This also works good on lower hulls of vehicles for road dust and grime. Use it sparingly though. Too much and you may as well repaint the vehicle.
"Imagination is the dye that colors our lives"
Marcus Aurellius
A good friend will come and bail you out of jail...but, a true friend will be sitting next to you saying, "Damn...that was fun!"
