I just realized something..
On the rear axle of the Tamiya kit, the Land Rover has an EMV (or is that EML? I forget the right letter right now..) differential. This is most likely not accurate because this make of differential is very rare, and in the event of the Land Rover having this diff, then it would have been replaced/refitted with the far sturdier Salisbury differential.. This diff is sustantially 'meatier' than the EMV diff and much preferred by the armed forces. The front differential, a Rover differential, is the same on all series 2, 2A and 3 88's and 109's (including 109 and 110 Forward Control models. I'm a bit hazy on the 101's..), except for the 1 tonne series 3 109's, which have Salisbury diff's front and rear.
Just so you know..
By the way, I have a Salisbury (so should Gregers..) on my Landy if you want photo material.
