Which tank are you working on? That will give us a better chance to answer your question. However, a tank usually has its strongest armor forward and there is no gap between the upper an lower hull in front. In the rear, there are lots of tanks with access doors, overhangs, grilles and such to the engine compartment.
Like they said, check photo references! If you need some, ask and the forum can usually direct you.
Ron
