Materials for zimmerit
Posted by Anonymous on Friday, March 7, 2003 3:12 PM
Hi, I´m a modeller who started recently, and I have this problem: I´m trying to build a King Tiger with a zimmerit coating, and I have the Tamiya zimmerit applicators. However, in the instructions of the applicators it says that I have to use polyester putty. Here in Chile is very difficult to get some tools or supplies, and I have never seen here polyester putty. So my question is, can I use regular putty? If not, are there some other materials that would work?
Posted by Buddho on Friday, March 7, 2003 7:52 PM
I have used spackling paste used to fill holes in walls. If it is too thick, just add a little water. Good luck!
Posted by Anonymous on Friday, March 7, 2003 8:11 PM
I cant say that I have had a whole lot of luck with zimmerit, but I will share some info that I hope will help you out. I have used regular Testors putty, and Squadron green putty to apply zimmerit. I have found that I prefer the Testors, because it has a slightly longer drying time. As far as how to apply it using the Tamiya applicators, I have two suggestions.
1) mask off what you don’t want covered.
2) Work in small areas.
Despite using the longer drying Testors putty there is still very little time to correct mistakes before it dries to the point where you’ll end up with a mess if you work with it anymore. So avoid working in big areas. Test it out on scrap, or the inside of the model. Like I said before, I have not had much luck with decent looking zimmerit, but I hope this helps. Please let us (or at least me) know how it turns out and what techniques you ended up using.
Good Luck!!
erickSmile [:)]
Posted by Moses on Saturday, March 8, 2003 3:35 PM
Zimmerit...every German modelers nightmare once you get the hang of it.
Well there are so many ways to apply zimmerit, and I probably have tried them all with varying degrees of success. Presently, I use Milliput 2 part epoxy (thanks Tony Greenland). It is a bit more messy then some other epoxies out there when wet, but it much more durable and easier to handle. It also has about a 2 hour curing time, so you have alot of time to work with it. The Tamiya Zimmerit applicator is an excellent tool to rack the zimmerit in the appropriate pattern (usually 2 mm in lenth for a proper 1:35 scale).
Also companies like Cavalier, Verlinden, and Eduard have made preformed zimmerit for various German armor. Cavalier's is made from resin and has tons of premade zimmerit's ranging from the Panzer IV's to the JadgTiger. They also have Generic patterns that you can cut to size and apply. As for Eduard and Verlinden, they make etched brass zimmerit. They are perfectly crafted and easy to apply (the fit is just awesome. So if you can get a hold of these, try em out. They usually range in price from $9.99 to $19.99.
If you ever want to gett a great lesson on applying zimmerit, pick up Panzer Modeling by Tony Greenland. He is just an amazing Master Class Modeler.
"ZIM FIRST, ASK QUESTIONS LATER!!"
