M1A1 Bad Blessing
M1A1 Bad Blessing
Posted by HeavyArty on Friday, February 11, 2011 9:29 PM
I have been working on this project for a while, but just haven't had time to post about it.  I am building an M1A1 named "Bad Blessing" from B Co, 1-35 AR, 1 AD seen in Iraq in July of '08.  I am using the below pics (among others), from the Tankograd TUSK book (I think thats where they were from) as references.
I started with the Tamiya M1A1/A2 kit and added anti-slip coating using the Rust-Oleum Terra Cotta spray technique that I showed here a while ago.
I also used as many left-over parts from my last Dragon M1A2 SEP project (grey parts) as possible to raise the level of detail a bit.  I added wire springs for the front fenders too.  I also scratched the shields around the TC and the loader with 0.30 sheet styrene.  I found some "Z"-shaped rod from Plastruct that worked perfectly for the frames around the armored windows.  A bit of expanded PE mesh for the one shield between the TC and loader finished them off.
For the rest of the TUSK parts, I used the excellent Legend TUSK I set.
Here it is with the TUSK parts propped in place prior to painting.
Next I applied the camo paint to the tank and the sand paint to the TUSK parts separately, then joined them after painting.  I detail painted the TUSK parts and hull before combining them and adding weathering.  I used Testors Model Master enamels for the base coats and acrylics for the weathering.
Here is the finished project.
More pics here.
As always, all comments and critiques are welcomed.
    January 2006
Posted by SprueOne on Friday, February 11, 2011 9:43 PM
nice! Your model looks just like the ref.
what material did you use for the clear armored windows in the shields?
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
Posted by HeavyArty on Saturday, February 12, 2011 6:37 AM
Thanks SprueOne.  It was a fun project.  The armored glass is thick, clear styrene (about 0.060 I think) that comes in the Legend TUSK II set.  It is included for that purpose.
    September 2007
Posted by SuppressionFire on Saturday, February 12, 2011 7:07 AM
Excellent M1A1!
Yes agreed the model is a miniature of the reference photographs.
Not shown is the right side, did you replicate the rather large stain on the skirt armor?
I really like the chains on the back, with a suitable background a 'eye level' photograph could capture the tank to look exactly like your reference pictures.
http://i6.photobucket.com/albums/y211/razordws/GB%20Badges/WMIIIGBsmall.jpg
Posted by HeavyArty on Saturday, February 12, 2011 7:29 AM
Thanks SupressionFire.  I tried to get it as close as possible.  The stain is there too...
    September 2007
Posted by SuppressionFire on Saturday, February 12, 2011 7:44 AM
The reference picture looks like a oil can was shot right beside the tank and the stain has picked up dust / dirt.
With the picture to support this theory it would fly on a contest table, to just have that large odd stain would create negative points at a contest. I see your restrained version will 'keep it real' without creating a 'WTF is that on the side?' comment at said contest.
    July 2006
Posted by redleg12 on Saturday, February 12, 2011 7:52 AM
OH man you have been holding out!!!....Very nice, great to see a camo and sand mix modeled. Love the cooler on the turret roof. Stunning, As usual, right on target!
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    August 2003
Posted by Nachtflieger on Saturday, February 12, 2011 8:05 AM
Wow! Beautiful job. I especially like the precise application of the 'no slip' surface......excellent!
Nate
Posted by HeavyArty on Saturday, February 12, 2011 8:12 AM
SuppressionFire - the actual stain is most likely a fuel overflow.  The filler for one of the forward fuel tanks is right above it on the hull top.  I did tone it down a bit though.  Glad you like it.
Mike - thanks buddy, I'm glad you lik eit.  Yup, I've been busy and didn't have time to post about it.  I too like the sand on camo look.  This one is actually on commission, so I think I will have to do a sand/camo version for me too.  The cooler is from a Legend Abrams accessory set.  It is probably the best cooler I have seen in 1/35.  It is really nice.
Nate- Thanks.  The spray on technique for the non-slip coating makes it pretty easy really.  You should give it a shot.
    January 2008
Posted by RMC_Birdgunner on Saturday, February 12, 2011 8:33 AM
Wow, awesome looking Abrams. You have certainly raised the bar with this one.
Denis
"Public opinion wins wars." - Dwight D Eisenhower to Monty, Sept. 1944.
Posted by rjkplasticmod on Saturday, February 12, 2011 8:38 AM
Excellent Build Gino Yes.  Thanks for sharing.
Regards,  Rick
    March 2008
Posted by modelchasm on Saturday, February 12, 2011 9:15 AM
NICE JOB, Heavy!!! Really nice. I like the scratch-work you put into it a lot.
Just FYI ... in the future, if you have a kit that needs armored glass but doesn't come with it, you can get small acrylic sheets at places like Home Depot. Then just cut out small squares for the windows using a cutting wheel/ disc on a dremel. POOF! Instant armored glass .... (I think you can even buy it in green tint...)
Nice job again, Gino ... hadn't heard of that anti-slip technique before .. thanks for the link!
"If you're not scratching, you're not trying!"  -Scott
Posted by tigerman on Saturday, February 12, 2011 1:17 PM
That's cool. Very different rendition of the M1. Refreshing to see it in the tri-color cam as well. I like the subtle weathering on it and say you did a fine job replicating your reference.
 Eric
Posted by HeavyArty on Saturday, February 12, 2011 2:29 PM
Thanks for the compliments guys.  I too really like this one, especially the contrast between the camo and sand paints.
    April 2015
Posted by spadx111 on Saturday, February 12, 2011 2:54 PM
Yes nice job.Ron
    May 2005
Posted by terry35 on Saturday, February 12, 2011 3:38 PM
She is just a beauty, I love every aspect of your build. By far the best modern piece of armour I've seen in a long time.
Terry.
Posted by HeavyArty on Saturday, February 12, 2011 4:13 PM
Thanks Ron and Terry.  I did enjoy building this one.
    July 2004
Posted by wbill76 on Saturday, February 12, 2011 4:23 PM
Very nice work Gino, as the others have mentioned the different camo schemes really makes this one an eye-catcher and the replication work vs. the photo is top-notch as well. Beer
    June 2005
Posted by minimortar on Saturday, February 12, 2011 5:33 PM
Awesome as always Gino although, this one has got to be one of my favorites. Don't know how you do it but I'd have a hard time giving these up after putting my heart and sole into them like you do. I'm not so sure that I could put a price tag on those.
Thanks,
Kevin Keefe
Mortars in Miniature
A Scale Model (Plus!) Collection of the Infantryman's Artillery
    April 2005
Posted by wing_nut on Saturday, February 12, 2011 7:42 PM
How did you cut the tank out of those 1st pics so perfectly?  I can't do that.Wink
Marc
  • From: 41 Degrees 52.4 minutes North; 72 Degrees 7.3 minutes West
Posted by bbrowniii on Saturday, February 12, 2011 8:43 PM
Gino
Really great build. Pretty interesting that even that late in the war some of the tanks were sent without a desert paint job.
Good stuff!! Yes
'All that is necessary for the triumph of evil is for good men to do nothing' - Edmund Burke (1770 ??)
Posted by HeavyArty on Saturday, February 12, 2011 9:28 PM
Thanks Bill and Marc or looking in and for the compliments.  I enjoyed this one.
Kevin - Thanks for the compliments.  I figure I can always build another for myself.  It also gives me a way to keep from needing more shelf space for them.
bbrownii- actually, no vehicles are repainted from camo to sand when they are sent to Iraq.  I guess the powers that be figure it is cheaper to leave them in the camo than repaint them.  The color isn't really an issue anyways, they are the only amor there and a few days in the desert and they are covered in sand anyhow.
    January 2009
Posted by camo junkie on Sunday, February 13, 2011 9:30 AM
have to throw my 2cents in gino...looks really good. just out of curiousity only, how much extra weight is all that armor on the actual tank?
"An idea is only as good as the person who thought of it...and only as brilliant as the person who makes it!!"
Posted by Tojo72 on Sunday, February 13, 2011 9:43 AM
your level of detail is oalways outstanding.great job.
    April 2005
Posted by JohanT on Sunday, February 13, 2011 9:51 AM
Awesome.
I am fortunate to say that I have never seen one of these before.
That is one scary Abrams and the accuracy of your build is just top notch.
I am going to try your Anti Slip technique on my next STRF 90, looks just right!
Very Best Regards
Johan
    May 2009
Posted by Pawel on Sunday, February 13, 2011 9:51 AM
Hello Gino!
I noticed this one a little late, but it's an excellent model as always. This time I even like your painting on this one Big Smile A beautiful blend of sand and woodland components. So what are you working on now? Good luck with your projects and have a nice day
Paweł
www.vietnam.net.pl
Posted by HeavyArty on Sunday, February 13, 2011 12:19 PM
Thanks for the compliments guys.  I'm glad you like it.
Camo - I don't know how much extra weight the TUSK adds, but it is quite a bit.  The Abrams has plenty of extra power to carry it all though
Pawel - Thanks, I'm glad you like the painting on this one.  No pre-shading though.  This is my standard washes and drybrushing as always.  It just shows up better in pics on the darker camo background.
Posted by bbrowniii on Sunday, February 13, 2011 2:40 PM
HeavyArty
Gino
Really!? I'm embarrassed to admit that I had no idea - all of the Marine Corps M1s I saw in 2005 were sand so I just assumed... guess we all know where that gets us, huh? Stick out tongue
Posted by HeavyArty on Sunday, February 13, 2011 7:11 PM
No problem and that was a good guess.  Another example of the Army not always doing what one would expect.
Posted by cyeargin on Sunday, February 13, 2011 9:50 PM
Regarding the weight, according to the Tankograd TUSK book, the belly armor alone adds 1300 KGs; not sure about the tiles. Gino, again, very nice job...you continue to be a true inspiration. Wink
