Sanding AFV wheels via dremel?
    June 2010
Posted by DoogsATX on Friday, March 4, 2011 1:17 PM
I remember reading a suggestion awhile back about attaching AFV wheels to a dremel to make sanding easier.
Makes sense...but what's used to attach them? The standard mandrel screw isn't deep enough to mount VVSS wheels.
Anybody?
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    April 2005
Posted by wing_nut on Friday, March 4, 2011 1:22 PM
A drill bit that has a tight fit... almost has to be "screwed" on the end... chucked in a Dremel works.
Marc
    June 2010
Posted by DoogsATX on Friday, March 4, 2011 1:44 PM
Awesome! Drill bits I have in abundance!
    July 2004
Posted by wbill76 on Friday, March 4, 2011 6:39 PM
Just be careful about your speed and duration of exposure settings. Styrene will melt if subjected to sufficient high-speed friction. Wink
    April 2005
Posted by wing_nut on Friday, March 4, 2011 6:42 PM
OH YEAH... What he said!!!!
Marc
    July 2006
Posted by redleg12 on Friday, March 4, 2011 7:30 PM
Use a scotch brite pad rather than sand paper and constanly check on how it looks
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    February 2010
Posted by EBergerud on Friday, March 4, 2011 7:37 PM
You have one of those variable chucks for your Dremel? Think they only cost about $5 - then you could stick in something pretty thick down to something like a needle. They work very well in my experience.
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
