Stripping Vallejo
    May 2008
Stripping Vallejo
Posted by BeltFed on Friday, March 11, 2011 8:15 PM
what should i use to strip off Vallejo Paint?
    June 2010
Posted by DoogsATX on Friday, March 11, 2011 8:18 PM
I recently had some unintentional success with Micro Set. Have you tried an ammonia-based cleaner, like Windex?
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
    May 2008
Posted by BeltFed on Friday, March 11, 2011 9:08 PM
Windex doesnt seam to harm it. I tried it on some jars i had laying around. Micro Set is essentially white vinegar. hmmm.
    July 2014
Posted by batai37 on Friday, March 11, 2011 11:47 PM
Super Clean works on pretty much everything.
    August 2005
Posted by Phil_H on Friday, March 11, 2011 11:51 PM
Denatured (ethyl) alcohol will rip it clean off.. It won't harm the plastic either.
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Saturday, March 12, 2011 1:24 AM
  I soak 'em in purple power.
http://images.buzzillions.com/images_products/02/72/purple-power-industrial-strength-cleaner-degreaser_5413080_175.jpg Walmart  and Advance auto......
Others here use simple green
 http://img2.prosperent.com/images/250x250/www.restockit.com/images/Product/medium/13005green.jpgat Walmart
they will work.
                                                     http://i20.photobucket.com/albums/b232/gluetank/Animated/th_1-Animated-Disastermaster.gif?t=1296616998
 https://i.imgur.com/LjRRaV1.png
    May 2008
Posted by BeltFed on Saturday, March 12, 2011 9:50 AM
Currently soaking the tank in question in purple power. lets see if it can blast through oils, some enamels, future, and vallejo paint....
    May 2008
Posted by BeltFed on Saturday, March 12, 2011 12:36 PM
    July 2003
Posted by madmike on Saturday, March 12, 2011 7:59 PM
My wife uses Pollyscale  ELO (Easy Lift Off) paint remover or Windex to remove Vallejo paints from purchased painted 25mm mini's or ones she is not happy with finish wise.
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." - Galileo Galilei
    January 2006
Posted by SprueOne on Saturday, March 12, 2011 9:51 PM
what is the base of Vallejo paints? I've been using the Purple Pond for paint stripping with no problems to the styrene plastics
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    July 2003
Posted by madmike on Saturday, March 12, 2011 11:06 PM
They are acrylics
    January 2006
Posted by SprueOne on Saturday, March 12, 2011 11:14 PM
acrylics, yeah Purple Pond should do it
Tags: Purple Pond
    May 2008
Posted by BeltFed on Sunday, March 13, 2011 9:43 AM
The Purple Power stuff is beginning to work after almost 24 hours of soaking. It is even removing the primer coat of Tamiya Spray paints. However, both paints (and some small fittings....) are only coming off after some very serious scrubbing with a toothbrush
    July 2003
Posted by disastermaster on Sunday, March 13, 2011 11:24 PM
Patience.
    February 2010
Posted by EBergerud on Monday, March 14, 2011 3:41 AM
My suggestion would be Goo Gone - available in small bottles anywhere for about $2. Very good at handling stains of any kind but strips paint very nicely and does no damage to the plastic. Just brush it on and wait for a few minutes and use a q-tip, paper towel and a tooth pick. Works good every time I've tried it.
Eric
A model boat is much cheaper than a real one and won't sink with you in it.
    April 2011
Posted by Crazy Horse Lady on Sunday, April 10, 2011 4:10 AM
Acrylics, even sealed, don't stand a chance with Dawn Power Dissolver and a Ziplock Storage bag. I've used it on resin and cellulose acetate plastic safely. Big Smile
˙ǝsɹoɥ ʎɯ uo ʞɔɐq ǝɯ ʇnd puɐ dn ǝɯ ʞɔıd ǝsɐǝןd 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
Equine X Design
Specializing in equine model prep and finishwork.
Feel free to visit the website, check out the gallery, and say hi!
    August 2018
Posted by seminole360 on Sunday, February 23, 2020 10:03 AM
I used 91% isopropyl alcohol on a resin print and it stripped Vallejo Model Color acrylic after about 5 min, without harm to the resin. It even stripped most of the Tamiya aerosol primer coat. *I know this is an old post, but I got here seeking the same info and it was a little unclear.
