Hobby Boss #85501 152mm ShkH Dana vz.77
    January 2006
Posted by MECHTECH on Sunday, March 27, 2011 9:49 AM
Well I started on this kit this week and so far I have found only one problem with the instructions. Hmm
I have no pictures to show but in step 10 when you are assembling the wheels ( parts A23 with A 21 <Sub-assembly C-C> and A22 with A 21 <sub- assembly D-D>) for the rear suspension, part A23 needs to be switched with A22 in order for the brake arm (Parts A18) assembly to match up.Geeked
Other than this mis-step, the model looks pretty good so far. I hope to be able to submit pictures in the future.YesWhistling
    March 2007
Posted by JEFFB on Sunday, March 27, 2011 3:04 PM
I'm building the same beast over on the group builds!
    March 2007
Posted by JEFFB on Sunday, March 27, 2011 3:08 PM
Its a great build, button up the boring interior..its a nice kit.  I've added some details over on the group builds....spg/ arty.
I also found something on mine...the side stabilizers were different lenghts . after gluing them down, one side looked half extended!!!!  Guess it would be ok in a dio?
    July 2003
Posted by zokissima on Monday, March 28, 2011 8:27 AM
Been wondering about this kit, as reviews seem to be scarce.
    January 2006
Posted by MECHTECH on Tuesday, March 29, 2011 9:14 AM
Except for the Drivers cab there is no detail. Probably in the works from Eduard or someone else.Idea
The kit so far seems to go/fit together rather well with few problems so far. I am building mine using what few pictures are available on the web of the cab interior. Although the instructions call  for a flat white interior, the pictures I have seen so far show a colour much like the Soviet interior white seen in the past( a dirty brownish tinge to the white).  They probably use diesel or gas as a thinner for the paint before applying. Huh?
They even include a small jig for bending small PE hooks. I glued mine together and have had no problem with the bends so far, except as you can only do one at a time when it made with grooves/holes for four.Hmm
 So far, a decent kit of an obscure vehicle. I would rate it a 89% out of 100.  I only hope I can do it justice on the paint job.Embarrassed
    March 2007
Posted by JEFFB on Tuesday, March 29, 2011 5:37 PM
Have ya chosen a color scheme for yours yet?
You cleared something up for me..the jig for the hooks!  I didn't realize it was for the hooks!  It looked like an ammo can.
    January 2006
Posted by MECHTECH on Tuesday, March 29, 2011 6:34 PM
Jeff
I found one that has the dark green base with flat black lines drawn over. Looks interesting and different. Also like the grass green/light brown and black como. I want it to be a Czeck vehicle as that is the home country.Hmm
