Tamiya 1/35 Marder III
    August 2003
Posted by Nachtflieger on Saturday, May 21, 2011 7:44 AM
Hi All,
I thought I'd share some pics of my recently completed Marder III for Tigerman's Panzerjager group build. I replaced the kit tracks with a set of Friuls, used Archer Transfers, and an RB productions antenna. I swiped the crewman from Tamiya's Wespe kit, and painted them with Vallejo paints. I also used Archer's transfers for their shoulder boards.
The kit was painted overall panzer gray from Tamiya, then filters and washes were applied. I used Mig pigements along the hull sides, and Tamiya weathering powders for the white wash.
I made a base using paper mache for the ground work, followed by Verlinden winter static grass, and Woodland Scenics field grass. I then sifted baking soda overall, and sealed everything with hairspray.
Overall, I'm pretty happy with how it all turned out. The kit was a dream to build, but I had a lot of trouble with the tracks. For some reason, they kept separating which meant I'd have to remove the bad link, and the link before it. Luckily, there were plenty of spares, so I didn't run out.
Thanks for looking, and comments welcomed.
Nate
Posted by Bish on Saturday, May 21, 2011 7:49 AM
This looks very nice indeed. And i like the base alot. Yes
    August 2003
Posted by Nachtflieger on Saturday, May 21, 2011 8:08 AM
Thanks Bish!Big Smile
Nate
    September 2009
Posted by Hinksy on Saturday, May 21, 2011 8:40 AM
Lovely job! Star
I also built this kit a long while ago as one of my earlier builds - for a Tamiya build it was tricky but it turned out fine. I think I found it hard because I was a total newbie at the time! If I built it now (I'd actually like another crack at it anyway) I'm sure I'd fly through it.
I seem to remember that I used the kit supplied one piece tracks? Did it also come with link & lengths too? They used to scare me! LOL!
I do like the fact that you didn't use the kit figures. I did and they are very good but it's nice to see one of these builds with two cold, hunched figures waiting for action! Thet are extremely well painted - nice work.
Thanks for sharing this with us Yes
ATVB
Ben Toast
On the Bench - Dragon Pz. IV Ausf. G (L.A.H.) Yes
Your image is loading...
    August 2003
Posted by Nachtflieger on Saturday, May 21, 2011 9:00 AM
Thanks a lot Ben.
No, the kit only comes with the rubber band tracks. They look good, but are a bit too long. Plus, I like the sag with the metal tracks. The orignal figures look good, but I wanted to do a winter scene, so I went with these guys.
Nate
    September 2009
Posted by Hinksy on Saturday, May 21, 2011 9:19 AM
Nachtflieger
Thanks a lot Ben.
Nate
Sorry Nate - I didn't see the bit where you mentioned that you'd used Friuls! Embarrassed
How were they separating? Sounds odd?
That said I've got a set of 38(t) Friuls in my kit box and they are terrible! I can normally assemble one run of Friuls in about 90 minutes but when I tried assembling mine I found that every single link needed drilling out with the pin vice and they a bit too wide for my Tamiya Hetzer for which I had planned to use them on so they would sit properly!
In the end I decided that because I'd be using the Schurzen the top run would be totally hidden negating the need for a realistic looking top run - they would have been totally hidden!
I've still got them and plan to use them on my Daragon Marder at some point.
Did you experience this problem with your Hetzer Friuls like I did? If so there is something definately not right with them but it looks like you did good anyway!
Here's my old Marder. One of my first 1/35 builds and my first use of figures - it's still a favourite of mine:
ATVB
Ben Toast
    April 2009
Posted by deafpanzer on Saturday, May 21, 2011 10:01 AM
Yes Impressive work! Yes What's more I am impressed that you had the guts to built another Marder... I swore that I will not build another Marder for a long time because it took me forever to finish it. Stick out tongue
Andy
    August 2003
Posted by Nachtflieger on Saturday, May 21, 2011 10:11 AM
Thanks Andy!  Even though I still have 3 left to complete my collection, I think I'm done building Marders for a while!!!Dead
Nice job on your Marder Ben.Yes
As for the tracks, I drilled out every link also. I used a dremel to speed it up, but it was still tedious work. Where the links separated, it looks like the wire that holds the links together sliced through the white medal of the link itself. I've used Fiuls before, and haven't had this trouble. Not sure why it happened this time.
Nate
    February 2011
Posted by MAJ Mike on Saturday, May 21, 2011 10:13 AM
Nicely done.  Makes me cold just looking at it.
 "I'd "I'd rather be historically accurate than politically correct."
"Sic gorgiamus allos subjectatos nunc!"
    August 2003
Posted by Nachtflieger on Saturday, May 21, 2011 10:17 AM
Thanks Maj Mike! That's the effect I was going for.
Nate
    September 2009
Posted by Hinksy on Saturday, May 21, 2011 11:14 AM
Nachtflieger
Nate
Thanks Nate - I was really chuffed with that whitewash finish. It was a total fluke and looked really good Whistling
As so far as you Friuls go, it sounds to me like you you used a slightly oversized drill bit perhaps? I've done this before and it causes one end of the outside of the hole to split. The split gets worse and the links separate. I've used a lot of Friuls now but have never had to drill out EVERY hole on each link before my I used the 38(t) links like you.
Heck, when I sat down to assemble my StuG III B links the other weekend I honestly didn't have to drill one single hole out - they were all perfectly clear!
Still, at least it turned out really well and that is one Marder that anyone should be proud of!
ATVB
Ben Toast
Posted by Tojo72 on Saturday, May 21, 2011 11:59 AM
wow those shades of gray look outstanding,the crew and vehicle look very cold !!
    April 2009
Posted by deafpanzer on Saturday, May 21, 2011 12:08 PM
Three more to go?  Boy, I have a long way to go... only finished one and you have seen it.  Hope I live long enough to build them all.  Now you have made me curious which three you haven't completed...
Andy
    August 2003
Posted by Nachtflieger on Saturday, May 21, 2011 1:12 PM
Hi Andy,
I still have to do the Marder II, Marder IID, and Marder I Hotchkiss.
Nate
Posted by BaBill212 on Saturday, May 21, 2011 1:39 PM
VERY nice Nate....  the entire composition works well - - the kit looks great, the base and the figures = A+
PS
I've not had that Friul track problem before.....  hopefully just a fluke. I use a pin vice hand drill on these (mindless, tedious work,, but worth it in the end)
Thanks for sharing............ !
Bill
Enjoy the ride!
    August 2003
Posted by Nachtflieger on Saturday, May 21, 2011 1:53 PM
Thanks BaBill.Big Smile
Yeah, it was probably my fault for drilling out every link. I probably made them too weak by doing so. I just drilled them as a pre-emptive measure. They didn't all need to be drilled, I just did them all at once so I wouldn't have to stop assembly to re-drill. I'll know better next time.Wink
Nate
    July 2004
Posted by wbill76 on Saturday, May 21, 2011 2:50 PM
Very nice work all around on this one Nate, glad you shared it with us! Beer
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Saturday, May 21, 2011 3:38 PM
Some seriously good looking work here Nate.
I really like the "LʘʘK."
http://i20.photobucket.com/albums/b232/gluetank/Animated/th_1-Animated-Disastermaster.gif?t=1296616998
 https://i.imgur.com/LjRRaV1.png
    August 2003
Posted by Nachtflieger on Saturday, May 21, 2011 4:23 PM
Bill, and Disastermaster: Thanks alot, I really appreciate the feedback!
Nate
Posted by jimz66 on Saturday, May 21, 2011 6:55 PM
Very nicely done Nate. Great job. Thanks for posting. d
Phantoms rule the skies!!!
Posted by tigerman on Saturday, May 21, 2011 8:50 PM
I love the whole thing Nate. As said, very cold.......
I like those numbers, gives it some character. Nice tonal variations.
Thanks Nate for participating in the GB. Smile
 Eric
    August 2003
Posted by Nachtflieger on Saturday, May 21, 2011 9:53 PM
Jimz66 and Tigerman: Thank you for the feedback.Big Smile
Eric, thanks for hosting the build....it's been fun!
Nate
    March 2004
Posted by Mikeym_us on Saturday, May 21, 2011 10:16 PM
Nachtflieger
Nate
I use a pin vice and a bit that is the same diameter as a straight pin to drill out the holes to install straight pin track pins.
On the workbench: Dragon 1/350 scale Ticonderoga class USS BunkerHill 1/720 scale Italeri USS Harry S. Truman 1/72 scale Encore Yak-6
The 71st Tactical Fighter Squadron the only Squadron to get an Air to Air kill and an Air to Ground kill in the same week with only a F-15   http://photobucket.com/albums/v332/Mikeym_us/
    May 2005
Posted by terry35 on Sunday, May 22, 2011 10:56 AM
Brilliant finish there Nate,  I feel cold looking at the pic's. especially this one.
http://img.photobucket.com/albums/v119/transitmek/nikonpics980.jpg
Congrats on an excellent model.
Terry.
    August 2003
Posted by Nachtflieger on Sunday, May 22, 2011 1:30 PM
Mike: Good tip on building the tracks, thanks.
Terry: Thanks, I appreciate it!Big Smile
Nate
  • From: 41 Degrees 52.4 minutes North; 72 Degrees 7.3 minutes West
Posted by bbrowniii on Monday, May 23, 2011 3:56 PM
Nate
I know I told you this the other night at the club meeting, but GREAT job. Looks sweet.
'All that is necessary for the triumph of evil is for good men to do nothing' - Edmund Burke (1770 ??)
    August 2003
Posted by Nachtflieger on Monday, May 23, 2011 4:49 PM
Thanks Boyd!Big Smile
Nate
    October 2009
Posted by PANZERWAFFE on Monday, May 23, 2011 6:29 PM
Think already said this in the GB but excellent job!  Really captured the feel with the whitwash, figures and base.  All VERY WELL DONE Yes
Rob
    August 2003
Posted by Nachtflieger on Monday, May 23, 2011 6:43 PM
Thanks Rob, I appreciate it!
Nate
    October 2009
Posted by jetmodeler on Monday, May 23, 2011 7:43 PM
Very nice.
Excellent job all around. I really like the base too.Toast
