There's the link and two end brackets. Might be worth it to fix up some kind of jig to hold the brackets in alignment! There are two little pins on the end of the link. You have to hold two links next to each other, then glue the bracket's two little holes over the two link's adjacent pins. It's actually easier to glue the bracket to one link and let set up a bit, then to the second link on one side. Then after that's firmed up just a bit, glue the bracket to the other side of the link. At least it was easier for me than trying to hold all those parts in alignment at the same time (which I obviously didn't do very well!)
I've now done one set of Jaguar tracks (Elefant), one Friulmodel (PzII), and one half set of Model Kasten (Panther). They all had their areas that were harder and others that were easier than the other types.
Good luck with them what every you use!
Bill
Bill
![](http://img.photobucket.com/albums/v233/wipw/DML%20Sherman%20Red%20Army/Finished1.jpg)
DML M4A2 Red Army
![](http://www.bestanimations.com/Flags/Usa/USA-04.gif)
![](http://www.info.com.ph/~tdwight/pantherGB.jpg)
![](http://members.fcc.net/ice9/badge.jpg)
-- There is a fine line between "hobby" and "mental illness". (Author unknown)
