Hey all. Third tank in, and I'm taking my first stab at whitewash.
I was going to try the hairspray technique, but it seems better suited to heavily worn whitewash, and this particular tank seems to have sported a fresh, factory-applied whitewash, so I wanted to go a bit more uniform.
But I still want to wear it down a little bit before I move on to weathering.
Is it common to drybrush the base color over the whitewash around edges, hatches, etc? I think it could either look really good, or awful, but can't sort out which in my mind...
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck: 1/350 HMS Dreadnought
hey doogs
wbill76 has a nice whitewash panzer WIP on his blog:
http://www.bpmodels.net/Model/Album/phpBB2/viewtopic.php?t=24
looks like drybrushing is a great option.
cheers
andy (lundergaard)
Just making the link active:
I was happy with the results that dry-brushing provided. Very controllable and you can always counter-dry-brush if needed if you go too far/overboard.
BP Models
One thing to consider with white-wash is that the worse it looks,the more accurate it is.It depends on the look you are going for.
What about the notion of wet, white Mig pigments applied over panzer gray base coat, and then removed as needed? I'm thinking about this method for field-applied whitewash, and it seems like a scaled version of the real thing. Am I in for an unpleasant surprise with that?
Steve M.
On the workbench: ginormous Kharkov dio
I’m a big fan of getting a photograph of the real thing. As Yogi Berra said, “You can observe a lot by just watching.” This photo is from the Allied side (sorry) , but shows FRESH whitewash (in other words, this is as good as it’s ever going to look) and may be useful to you:
Whitewashing an M36 Tank Destroyer at Dudelange, Luxembourg, January 3rd 1945.
Occasional factual, grammatical, or spelling variations are inherent to this thesis and should not be considered as defects, as they enhance the individuality and character of this document.
'Ya sure that was chalk?
Damn wish i had my scarface gif readily accessible
jadgpanther302 Damn wish i had my scarface gif readily accessible
You talkin' to me?
Thanks all!
Gave the drybrushing a shot last night...and it worked great! Think I may need to dial it back in a few places, but so far so good.
Didn't feel like dragging out the big Nikon, so here's a quick iPhone shot. For some reason it really picked up on the dunkelgelb and made it stand out far more than it does in person.
SteveM, the trouble you'll run into with using the pigment approach is keeping it thin enough and controllable. If you sprayed the pigments on via airbrush, that might work...otherwise it could be tough to keep it all in-scale in terms of the final result.
I find that using the pigment/ chalk aproach makes the model look like it was covered with chalk, not paint (i wonder why.....)
Doogs, it looks pretty good so far. I would recommend using some filters to tie it all together, as the dark yellow doesnt look worn. Just a thought.
