M247 turrett on a M1 chassis ......REDO
    March 2006
Posted by Shellback on Monday, June 6, 2011 9:16 PM
I took the turret from Tamiya's Sgt. York and mounted it on a  AMT-ERTL  Abrams hull . Thats an old kit with poor detail . Theonly  modification required was making the turret ring opening in the hull smaller which i did with some sheet styrene . The camo is my own creation .The lenses are made from reflective party decorations .
Here is the finished camo with a gloss coat .
I decided to dirty up the surfaces to represent boot and shoe marks made by military and contracter testing personal . This vehicle would have been a one off vehicle to further test the capabilities of the Ford Aerospace DIVAD submition .  The Sgt. York was a failure not only due to its inadequate air defense capabilities  but also due to its M48 based chasis  inability to keep up with the M1 Abrams and M2/ M3 Bradley . Perhaps the M1 chasis under the M247 20 ton turret could have improved that performance .
Dirtied up .
I used ground up pencil lead rubbed over a base of flat black to represent the well cleaned and polished  40 mm Bofors .
I figurds that after a hard day of banging around inside the hull and turrett out in  the desert proving grounds the crew would have had a nightly schedule of meeting at a local tavern for a few brews to discuss problems and achienements . Going to work every day in this aluminum can would make a person look forward to the end of the day and a few cold ones . So the crew named it Sudsy . The decal i found off of an old auto kit sheet .
    January 2011
Posted by Chazzer on Monday, June 6, 2011 9:24 PM
GREAT TO SEE IT AGAIN!!!
ChazzerBlack Eye
    November 2007
Posted by Hellcat man on Monday, June 6, 2011 9:31 PM
Very nicely done, i like the refective ribbon for the sights its a neat trick.
 ALEX ZELYK
    February 2011
Posted by MAJ Mike on Monday, June 6, 2011 9:42 PM
Anything worth seeing is worth seeing again.  For the second time, supurb build. Toast
 "I'd "I'd rather be historically accurate than politically correct."
"Sic gorgiamus allos subjectatos nunc!"
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Monday, June 6, 2011 11:51 PM
http://img.photobucket.com/albums/v481/ladyelle/Most%20used%20emots/whew.gif
That was close......
glad to see it back.
And by the way;
a good presentation and some cool work here.
http://emoticoner.com/files/emoticons/smiley_faces/respect-smiley-face.gif?1302011415
'ya got MY vote.
http://i20.photobucket.com/albums/b232/gluetank/Animated/th_1-Animated-Disastermaster.gif?t=1296616998
 https://i.imgur.com/LjRRaV1.png
    July 2006
Posted by redleg12 on Tuesday, June 7, 2011 4:47 AM
Bow Down Bow Down Bow Down Bow Down Bow Down Bow Down Bow Down Bow Down Bow Down Bow Down Bow Down Bow Down Bow Down Bow Down
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
Posted by Rob Gronovius on Tuesday, June 7, 2011 6:08 AM
Glad to see it back. As I mentioned before, I built this "what if" about 10 years ago when I first moved to Massachusetts. I've moved twice since then and I do recall securely storing the kit in a shoe box with some packing peanuts and tissue, but I doubt I could locate that box any time soon.
Yours looks way better than mine; I went with a Desert Storm era overall sand paint scheme. I started with the Tamiya turret and Tamiya original M1 hull that I updated and detailed into an M1IP hull, although if I was to re-try the build, I'd start with Dragon's M1 Panther II hull. Better detail and no need to update. I carefully cut the turret ring off of the bottom of the Tamiya turret and simply glued it to the underside of the York turret. Fit perfectly and worked like a charm.
I found photos (maybe in the Hunnicutt book?) with the commander's station equipped with an M60 machine gun. I used the one from the Tamiya M151A2 Jeep. I added the M1's smoke grenade launchers and made resin copies of the grenade stowage boxes from the Tamiya M60A3 kit.
I did some work to the turret top based on photos posted by Steve Zaloga some time ago. I do recall rebuilding and detailing the engine grill area. I know I added my tow cables to the turret rather than the hull as you've done.
It was an interesting and fun project. I hope you got as much enjoyment out of yours as I did from mine. I was surprised how big the thing turns out. It sits much taller than and Abrams. I assume only one or two would support a tank or mechanized infantry company/team. It would be such a large target. I contemplated adding ERA panels to the turret slopes, but thought that it would be a little much.
Thanks for re-posting your job well done.
Posted by HeavyArty on Tuesday, June 7, 2011 6:16 AM
Very nicely executed and interesting model.  I'm glad you reposted.  Good job.
    September 2005
Posted by treadwell on Tuesday, June 7, 2011 7:49 AM
Nice build, Shell,and in re-posting I think you have shown a lot of class.
best regards,
tread
    June 2005
Posted by minimortar on Tuesday, June 7, 2011 8:57 AM
Thanks Shellback! Looks great, cool, interesting and certainly futuristic! Too bad that it was never meant to be. Nice job on this (as well as the 247) and nice to have you back!
Bow Down
Thanks,
Kevin Keefe
Mortars in Miniature
A Scale Model (Plus!) Collection of the Infantryman's Artillery
    March 2006
Posted by Shellback on Tuesday, June 7, 2011 12:19 PM
Thank you everyone !
After reading the idea's of Robs  i'm thinking i may go out and find another Sgt. York kit for a future what if project . The posibilities are endless . And like agent.g said with the new technology its possible this vehicle could be effective as a DIVAD .
Thought i'd repost this picture of the entry that General Dynamics put up against the Sgt. York . From what i read it used the same target tracking  system as the CIWS , Phalanx . The radar was mounted on the front of the turret . The cannons were twin Oerlikon 35 mm cannons ..............................
..................like those used on the German Gepard .
Ratheon proposed using the turret from a Dutch version Gepard that could modified to mount on the M48 chasis ....Idea.... i have the Tamiya Gepard and that unused M48 hull in my stash !!!!!!This time i would update the rear of the hull to represent more closely this M247 at Yuma Proving Grounds .
This could be fun !
Sea
    July 2004
Posted by wbill76 on Tuesday, June 7, 2011 12:33 PM
Nice to see this one again! What-ifs are usually confined to the realm of post-WW2 but I like this application to a modern system more...and it sounds like you've got some inspiration for future projects as well that would be equally cool to see done. Beer
    March 2006
Posted by Shellback on Tuesday, June 7, 2011 12:37 PM
Thanks Bill !
One more thing ............did anyone notice the tracks on my kit ? Their the vinyle tracks off of the Testors Leopard II . The tracks that came with the Ertl kit were link and length and looked too flimsy .
    February 2011
Posted by MAJ Mike on Tuesday, June 7, 2011 1:04 PM
How about a Gepard turret on a Panther II hull?  Could be some kind of alternate history WWII scenario.  Lots of holes in the story, but might look cool.
Posted by Bish on Tuesday, June 7, 2011 4:58 PM
I missed this first time round, very glad you posted it again. thats one nice build. How did you get the footprint look all over it.
    March 2006
Posted by Shellback on Tuesday, June 7, 2011 6:37 PM
Bish
Thanks !!!
The footprints . I ground up some chalks of that color into a small container and added a little window cleaner to it ...just enought to make a paste . Then i used the end of a wooden tooth pick that i had shortened and shapped to roughly the correct shape to dab the paste onto the model . Further shapping was done with another sharp tooth pick .Its tediouse !!!!
    June 2005
Posted by minimortar on Tuesday, June 7, 2011 6:49 PM
Shellback
This could be fun !
Sea
Have a blast doin' it!! Big Smile
Thanks,
Kevin Keefe
  • From: 41 Degrees 52.4 minutes North; 72 Degrees 7.3 minutes West
Posted by bbrowniii on Tuesday, June 7, 2011 7:10 PM
Great build. I really admire how you were able to 'update' it to the more modern hull. Nicely done!
'All that is necessary for the triumph of evil is for good men to do nothing' - Edmund Burke (1770 ??)
    March 2006
Posted by Shellback on Tuesday, June 7, 2011 8:36 PM
MAJ Mike
Now that would be creative and require a good story to back it up .....................................Wink
    February 2011
Posted by MAJ Mike on Tuesday, June 7, 2011 8:42 PM
Shellback
 MAJ Mike:
Yeah, pretty lame.  I just like Panthers and alternate WWII scenarios.
At some point, I want to build a Republic of Texas Challenger tank.  Alternate history scenario of a balkanized North America with the U.S., Confederate States of America, and the Republic of Texas.
    March 2006
Posted by Shellback on Tuesday, June 7, 2011 9:02 PM
One mans creation is another man lame idea ?Or vise versa !Stick out tongue
And yes , Texas can run that Republic , just dont send their Navy to the eastern shores of Washington state , Olympia needs the invasion , not here  ...................Propeller
Posted by Bish on Wednesday, June 8, 2011 2:32 PM
thanks for the tip. Nice way to get that used look without having it covered in dust. Might have to try this on a 251 i am building soon, as i want a dusty look on the inside.
Posted by Rob Gronovius on Wednesday, June 8, 2011 3:01 PM
Shellback
One of the "to do" conversions on my list is the Super M60 update called the 120S. This was a heavily modified M60 chassis with an M1A1 turret being marketed to the Marines because they couldn't afford Abrams tanks at the time.
    March 2010
Posted by Hercmech on Wednesday, June 8, 2011 3:51 PM
Awesome...glad you brought it back...very stand up of you!Bow Down
13151015
    March 2006
Posted by Shellback on Wednesday, June 8, 2011 5:56 PM
Rob , now thats another interesting kit bash idea ! Is that the same as the the M60 -2000 ? I looked  up the 120s on Wikipedia and it stated that Egypt will start upgrading its M60 tanks this yr .but youd know more about that i'm sure .
Sea
    March 2006
Posted by Shellback on Wednesday, June 8, 2011 5:59 PM
Thanks again guys for your kind words ! Yes
    November 2006
Posted by dupes on Wednesday, June 8, 2011 8:33 PM
Shellback - really sweet build! Toast
Talk about "something you don't see every day"! Yeah
    September 2006
Posted by RBaer on Thursday, June 9, 2011 10:36 AM
Looks very neat, thanks for re-posting!
Apprentice rivet counter.
    March 2006
Posted by Shellback on Thursday, June 9, 2011 2:41 PM
Dupes and Baer thanks guys !!!!!!
Posted by grandadjohn on Thursday, June 9, 2011 3:43 PM
Great job
