Using a sharpie to paint/ color road wheels
    June 2006
Posted by Tankluver on Wednesday, June 8, 2011 9:11 AM
Is it fround upon to use a sharpie to paint/ color in the road wheels of armor? I read about it in the Carl McLaughlin How to Model German World War II German Armor. Just wondering what you guys think? Does anyone else use this technique?
Posted by VanceCrozier on Wednesday, June 8, 2011 9:15 AM
I've used a finepoint sharpie to outline the wheel hubs on landing gear wheels before. I'd be nervous about using one for an entire wheel though, the ink could separate under wet matte coats or drops of paint thinner. 2 cents
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    October 2009
Posted by Njal Thorgeirsson on Wednesday, June 8, 2011 9:19 AM
I think it would work well on a dull basecoat, but I wouldn't recommend it on plain plastic, because when one uses a sharpie on like, say, a plastic bag, the sharpie has this weird sheen, kinda like oil on water. Also, i'm not sure if sharpie is soluble in oil-based paint thinner (I assume it is not, but to me it would be very problematic if it were). Lastly and probably most significantly, many people (I included) prefer a shade of rubbery black with a little grey mixed in, because blackblack just looks too black (in my opinion), so sharpie might just be too black for some tastes.
But perhaps I'll have to give it a try!
FACEBOOK: Ryan Olson Thorgeirsson for pics of all my builds.
"There are two kinds of people in this world; those who put fries/chips on their sandwiches, and those who don't enjoy life."
PhotobucketPhotobucket
    August 2005
Posted by Phil_H on Wednesday, June 8, 2011 9:24 AM
I believe it may be problematic if you overpaint using Tamiya acrylics, as the alcohol base may cause the Sharpie pigment to leach through. I seem to recall reading of people using a Sharpie or similar to pre-shade and having the ink leach through in an oddly purple shade (the ink not being "pure" black).
Moderator
    April 2006
  • From: my keyboard dreaming of being at the workbench
Posted by Aaron Skinner on Wednesday, June 8, 2011 9:29 AM
I've used a Sharpie for some road wheel tires, usually when I'm in a little bit of a hurry, over both enamels and acrylics and under acrylic clearcoats with no problems. I'm not sure I'd recommend it for large areas, but the not quite black and the slight sheen look more like rubber than flat black paint. Bottom line, try it. If it works for you and you are happy with the results, then I say go for it, especially if it's less frustrating than trying to paint the tires.
Cheers, Aaron
Aaron Skinner
Editor
FineScale Modeler
    July 2004
Posted by wbill76 on Wednesday, June 8, 2011 12:09 PM
I used the method for a while but found the purple-sheen that it has to not be to my liking even after the usual weathering treatment and such. I instead switched over to using a draftsman's circle template and air brush my road wheels and get a much better result.
As Aaron mentions, give it a whirl. If you like the result, run with it. There's no hard-and-fast rules to be frowned-upon when it comes to finishing your model the way you want it to look. Wink
    June 2005
Posted by minimortar on Wednesday, June 8, 2011 5:29 PM
I believe that I tried this years ago and found that the ink ran when I dull-coated with Testors Dull Coat Lacquer. I think that's what happened. Something turned me off from it anyway. I prefer to put the road wheels etc on a piece of sprue (or sim) and do the paint and spin method. Piece of cake with no worries later on in the process.
2 cents
Thanks,
Kevin Keefe
Mortars in Miniature
A Scale Model (Plus!) Collection of the Infantryman's Artillery
    July 2006
Posted by redleg12 on Wednesday, June 8, 2011 6:59 PM
With Stupid  Use the same method as Bill Cowboy. For the tire color, I mix 50/50 Flat and NATO Black. Wink
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Wednesday, June 8, 2011 11:03 PM
http://th136.photobucket.com/albums/q192/zowzza/smileys/th_1lg026sad1.gif No frowning allowed here.......
                                        http://i20.photobucket.com/albums/b232/gluetank/Animated/th_1-Animated-Disastermaster.gif?t=1296616998
 https://i.imgur.com/LjRRaV1.png
    March 2007
Posted by KAYSEE88 on Tuesday, June 14, 2011 12:52 PM
LOL.....i did that once for all the wheels on Tamiya's Patton and i almost fainted from the vapors, but other than that it works good but you must follow with pigments to kill the shine   Whistling
    March 2006
Posted by Shellback on Tuesday, June 14, 2011 7:01 PM
Who would these "frowners"be anyway ?
I use something  cylindrical (plastic cap , tubing etc) held over the painted wheel and spray paint the tyre ...while trying my best not to "frown" .Super Angry
    December 2003
Posted by buff on Tuesday, June 14, 2011 7:30 PM
I use a Sharpie all the time.  I kill the gloss with a coat or two of Polly Scale Flat and it goes dead flat.  I've never had any issues with weathering them.
On the bench: 1/32 Spit IXc
    March 2010
Posted by ACESES5 on Wednesday, June 15, 2011 3:08 PM
I use the model master paint markers to do the rubber rims on tank road wheels they work great        ACESES52 cents
