Hi Richs26, Thanks for checking in and the info. I've heard that most M-12s had the t-51s, but; that a few had the t-49s. I found a pic of one that I think has t-49s on. I'll admit it's hard to tell with all the mud on the vehicle though. In the end since I'm not a big am kind of guy I went with the provided tracks. That being said, since there are not to many rubber band affecionados out there, I'd like to show how I did these tracks. If you will indulge me.
First off clean the tracks with a good degreasing agent, I used Simple Green. Then I used an enamel grey primer for my base. If you want a more rusty appearance then use an orange-ish base. Once the enamel was dry I covered it with a grimy black pigment from Doc O'Brien's pigments. I use pigments only after the primer. This keeps the paint from building up and cracking or flakng.
I then used a Rusty Brown on the "teeth".
This was followed by a Rusty Red in the same areas.
Then I put in some Grungy Grey to tone it down.
This was followed by a light dusting of Dirty Brown.
And that is it. I hope someone finds this helpful and that the pics came out well enough to see what was going on. I think I really need to make a Photo booth.
Well I'm off to muddy this bad boy up. This will be my first attempt at making and appling mud. Hope it comes out well. I'll get those pics up as son as I'm done.
-Stephen
