DML workable tool clamp
    December 2008
Posted by psstoff995's lbro on Tuesday, August 2, 2011 7:51 PM
How the Censored do you put these things together?
I can attach 'MA14' to 'MA19', but I can't get 'MA19' onto 'MA15' to save my life!! Suggestions?
-Will young modeler Test fit master
Posted by BaBill212 on Tuesday, August 2, 2011 8:31 PM
Unless I am actually working on it, I cannot be exactly sure,,   but as I see it,      15 goes into the front holes of 19,,,, and 14 curls over the top into the back holes of 19.
I would guess some of the other folks have probably built this pup before and may be able to shed some more light than I have.
Wish you the best with it...........
Enjoy the ride!
    April 2009
Posted by deafpanzer on Tuesday, August 2, 2011 9:17 PM
Oh God, I hated that part!  While I was building my Dragon Marder II, it wanted me to make like 15-20 clamps like this.  I couldn't make one successfully after an hour... I never felt so frustrated. Angry  I was told there are better aftermarket PE parts that contains only two parts instead of three like this.
However, I found a trick that helped me a bit... I would glue the part #15 on the hull or turret first using CA.  After allowing it to try enough.  Go ahead and glue the tools on then you can glue part #14 on top of the tools.  Finally you can add that P-I-A part #19 easily to the clamps already secured on the hull or turret.
Hope this helps...
Andy
    December 2008
Posted by psstoff995's lbro on Tuesday, August 2, 2011 9:28 PM
An hour!? You are a stronger man than I.
I like your idea though, and I will most deffinetly do that.
Thanks!
    October 2009
Posted by Njal Thorgeirsson on Tuesday, August 2, 2011 9:47 PM
Usually the problem for me seems to be the allignment of the pins on 14 and 15 with the holes on 19. I can never bend them so that the spacing (between 14 and 15) is correct. So what I normally do is bend 14 and 15, then gently shave the pins off of 14 (the pins that would normally go into 19)... then I put tiny CA drops under the tabs on 15 (the tabs towards the right side of the picture), and join 14 and 15. Then I bend 19 (slightly wider then it needs to be so i can close it around 14 and 15), then I apply glue to the inner side of the ends of 19, and pinch it around 14 and 15. HTH!
FACEBOOK: Ryan Olson Thorgeirsson for pics of all my builds.
"There are two kinds of people in this world; those who put fries/chips on their sandwiches, and those who don't enjoy life."
PhotobucketPhotobucket
