Tamiya 35227 Tiger I Initial Prod
    September 2011
Posted by pdash on Sunday, September 18, 2011 6:25 PM
Hello all, I'm new to the forum and to 1/35th scale modeling. I purchased a Tamiya Tiger Inital Production #35227. I would like to know what's the best color to airbrush / spray paint this unit. The instructions suggest that I paint using XF-60 which is Dark Yellow. Should I airbrush using XF-60 or XF-59? Also, what's the best tool to airbrush or should I use a spray can paint? Please advise. I apologize if this has been discussed before in previous postings.
Thanks,
pdash
    December 2006
Posted by Jester75 on Sunday, September 18, 2011 6:30 PM
You can use XF-60, but I like to lighten it up a good bit for scale when I do. Do you own an airbrush? If you dont, the debate on what would be a good started AB has been posted on significantly here on the forums. A quick search should yield loads of information to get you started on.
Eric
    September 2011
Posted by pdash on Sunday, September 18, 2011 6:47 PM
Hi Jester, thanks. If you like to lighten it up for scale, what color do you recommend? I don't own an AB. I will do a search on this forum. If you can recommend one for me, that would be great. Also, do you paint the treads and rim of the wheels? If so, what color?
pdash
    December 2006
Posted by Jester75 on Sunday, September 18, 2011 6:55 PM
Well for me personally, I dont have an exact recipe for lightening Tamiya's Dark Yellow. I just add white till it looks about right. IMO it should really look like a light tan when you are done.
As for airbrushes, I myself use an Iwata HP-CS for almost everything I do. Not the cheapest, but I started out with an old Aztek airbrush. I am by no means an expert on AB's so I would defer you to some of the members here that know much much more about them.
For treads and roadwheels, yes I paint them. I assume you have the rubber band tracks that came with the kit?? The rims of the roadwheels are rubber so a shade of black is what most use.  Alot of folks like to use some darker grays for the rubber and is looks more realistic. Some folks do it by hand, but there are some of us that use a drafting circle template. Paint the entire roadwheel the tire color, then you can come back and place the circle template over the roadwheel, effectively masking the rubber, and paint the base color on the center rim.
I am sure others will be along shortly to give you thier advice also. There is alot of talent here to be learned from to be sure!
Eric
