French 75mm M1897
    October 2011
French 75mm M1897
Posted by Chipps on Wednesday, October 12, 2011 12:39 PM
I am looking for several each of both of the following in 1/35 scale.
RPM 35007 7.5cm Mk.97 Schneider Field Gun wz.1897
DES 35042 75mm Model 1897 Gun
DES also has some additional equipment I would like to have several sets of as well.
It appears that Jadar in Poland has a version of the RPM kit. DES in France lists their kits on a web site, but I cannot find a way to order directly from them.
    July 2006
Posted by telsono on Wednesday, October 12, 2011 4:38 PM
I have one of the RPM kits and it comes with optional wooden or tired wheels for the cannon. As these are upgraded guns, the carriage would be different from that that the French used in 1940.
Mike T.
Beware the hobby that eats.  - Ben Franklin
Do not fear mistakes. You will know failure. Continue to reach out. - Ben Franklin
The U.S. Constitution  doesn't guarantee happiness, only the pursuit of it. You have to catch up with it yourself. - Ben Franklin
    October 2011
Posted by Chipps on Wednesday, October 12, 2011 6:37 PM
Thanks. I will be in touch.
    October 2011
Posted by Chipps on Thursday, October 13, 2011 12:56 PM
The consensus is the DES kits are preferred. I found a retailer that can acquire these. So I will try that route first. Thanks for the offer.
