This a Academy/Tamiya kit.
The kit is old and showing edge wear so that the mateing parts show a pronounced rim, which has to be removed. Otherwise fit is quite good except for the turret hatches, which fell thro' the turret apeture. So, some adjustment had to be made there.
I prefer to take photo's outdoors if I can but the winds here have been too strong, so the rest are taken indoors.
My first attempt at Zimmerit
I used Milliput ( which I could not get very thin ) and 'Polyfil' ( for filling cracks in walls ) which I prefer
I made a small stamp, which is just a piece of plastic with some saw slots, for scale I coppied a picture on the box art
The kit tracks are not so good. So bought a set of 'Academy' Indy link's which are quite good and easy to assemble. I fully fitted the tracks before painting, sofar so good!.
THEN my troubles started, they had shrunk. After severals times of breaking and re-gluing I decided to cut off the idler wheel axles and re-fit to allow assembly. By this time I had knocked or broken bits on the hull which also had to fixed.
For the cammo' I used this reference, not sure about the No tho'. I paint with brush and I do envy the way you guy's can do soft edge cammo' with your airbrushes
The kit schurzen were too thick and one piece so I made mine out of thin plastic card. I did think of some damage along the edges but was not sure I could do a good job of that!.
I am about to finish the tank commander but for now,,,, what do you think????.
I do not have any modeling friends that I can talk to or show and get help and advice other than the friends I have made on this forum, so your comments are more welcome...cheers.....Kenny
I have now added the tank commander but I need a lot more practic in painting figures
wbill pointed out that the brackets for the muffler were wrong, so I have corrected as best as I could within the restraints of the model
