Gater Grip? what?#"%
    November 2004
Posted by spacepacker on Thursday, November 3, 2011 7:35 AM
Just been trying some Gator Grip Glue; non-toxic (Acrylic Hobby Glue) and it will not stick.
The glue is white and a bit thick but spreads easily and dry's clear. The instructions say to thin with water but I dont know how thin it should be
I'm trying to to glue PE parts to plastic.
SO, what am I doing wrong?.
Looking forward to some help...cheers....Kenny
    December 2003
Posted by buff on Thursday, November 3, 2011 7:41 AM
  I use it regularly and have never had any issues.  I've never felt the need to thin it with anything.  I do use a brush dipped in water to clean up any extra, but that's about it.
On the bench: 1/32 Spit IXc
    December 2006
Posted by detailfreak on Thursday, November 3, 2011 10:19 AM
                        Perhaps your glue was frozen. I understand that freezing ruins it.
[View:http://s172.photobucket.com/albums/w1/g-earl828/]  http://i158.photobucket.com/albums/t104/cycledupes/1000Roadwheels4BuildBadge.jpg
    June 2010
Posted by DoogsATX on Thursday, November 3, 2011 10:26 AM
I've never had any problems using mine, and it's mostly replaced CA in my arsenal. As suggested, maybe it froze? Can you test it by just gluing two things together (sprue trees?) and leaving them? I know for me it'll hold very small parts pretty much immediately, larger stuff like big grab rails after about 30 seconds, and it sets pretty well and good after 10.
On the Bench: 1/32 Trumpeter P-47 | 1/32 Hasegawa Bf 109G | 1/144 Eduard MiG-21MF x2
On Deck:  1/350 HMS Dreadnought
Posted by VanceCrozier on Thursday, November 3, 2011 11:01 AM
Darnnit - I meant to order some of this stuff before the temperatures dropped up here, I don't dare ship it now considering I've woken up to a frosty windshield almost every day for the past week. Sad
On the bench: Airfix 1/72 Wildcat; Airfix 1/72 Vampire T11; Airfix 1/72 Fouga Magister
    December 2006
Posted by detailfreak on Thursday, November 3, 2011 11:17 AM
                              It is my understanding that dealers such as Sprue Bros. stop shipping when the possibility of freezing is likely.Just my 2 cents.
    July 2006
Posted by redleg12 on Thursday, November 3, 2011 1:51 PM
I keep min a bit thinner than white glue but not runny. If you put a toothpick in you should get an even film but it should not run.
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    November 2004
Posted by spacepacker on Thursday, November 3, 2011 4:55 PM
Buff, detailfrak,DoogsATX,Vancecrozier & redleg12, thanks for the help.
I dont think this has been frozen, I bought it in the summer and it has not been out of the house.
The consistencey would seem about right, I guess its meEmbarrassed...cheers....Kenny
    July 2004
Posted by wbill76 on Thursday, November 3, 2011 6:37 PM
Sorry to hear of your issues Kenny. I too use Gator Grip and it usually "grips" within a few seconds depending. Usually just need to hold pressure depending on how thick you apply it to the parts in question.
    November 2004
Posted by spacepacker on Friday, November 4, 2011 10:51 AM
I've done it, I apllied a lttle more Gator glue than I had been doing.
I think it works a little differently than CA glue, I know that CA glue works by dispelling all of the air between the two surfaces but it seems that Gator glue leaves a thin film between the two surfaces more so than CA glue.
I'm sure that there is a chemist amongst our members who will explain things so much better than I...cheers....Kenny
    March 2010
Posted by Hercmech on Friday, November 4, 2011 11:04 AM
I have tried (bought two bottles after reading it was the best thing since sliced bread) it but find it takes a long time to set up and does not hold all that well. I went back to superglue
13151015
    June 2010
Posted by DoogsATX on Friday, November 4, 2011 11:26 AM
Hercmech
What are you trying to glue with it?
I've found CA and GG have very different uses due to their properties.
I'd been using CA for a lot of uses where GG was really more appropriate, hence it's more-or-less replacement on my bench.
CA - generally excellent adhesive (sticks to other things) and cohesive (holds together) strength. Fast-curing. Excellent tensile (pulling) resilience. But because CA cures so hard, it's also exceptionally brittle. Not a huge problem if you've got a gear strut glued into a locating hole, or an entire wing glued to a fuselage. But for small bits - pitot tubes and grab rails and such - a very small glue area can be exceptionally vulnerable to shearing forces.
GG - Not as strong an adhesive as CA. It maintains a slight elasticity after curing, making it terrible for tensile applications (I tried to use it on some tension rigging on a biplane and it failed spectacularly) or for holding parts where there are opposing forces acting (I wouldn't use it to hold fuselage halves together, hold a stabilizer up, etc). But that elasticity also gives GG outstanding shear resilience, so for small fiddly bits that often get knocked off if stared at the wrong way, instead of flying off into nowhere due to a failed CA bond, they'll be laid flat, and can easily be stood back up.
GG is also an excellent replacement for white glue in general.
It's NOT a wonder glue. But for small parts that need to be placed, I find it far preferable to CA.
    March 2010
Posted by Hercmech on Friday, November 4, 2011 12:06 PM
DoogsATX
 Hercmech:
I have tried it for PE as well as canopies with both having diapointing results. the pe came off as soon as I tried to do anything with it and the canopy came loose as soon as I started to mask it. Maybe I got a bad batch.
13151015
    June 2010
Posted by DoogsATX on Friday, November 4, 2011 12:09 PM
That's weird, Herc. I've had to take an xacto to a canopy I just tacked on with a few dots of the stuff because the grip was so solid.
    April 2005
Posted by wing_nut on Friday, November 4, 2011 1:29 PM
detailfreak
                       ... freezing ruins it.
Nothing in life is certain except for death, taxes, and that statement.
Marc
    March 2010
Posted by Hercmech on Friday, November 4, 2011 1:56 PM
Maybe mine was frozen
13151015
