Workable link newbie
    June 2011
Posted by garylee on Wednesday, December 14, 2011 3:31 AM
Hi Guys,
After building about a zillion tons of aircraft models, I think it's time for a tank. I'm embarking on a project for my Uncle Georg to do a couple of models from the Battle of Kursk. I'm doing a Focke Wulf FW190 and a Tiger 1 (early), both in 1/48th scale. I bought the Tamiya Tiger 1 and picked up the AFV Club workable link tracks for it. The instructions are straightforward enough and I see how the links go together, but I was hoping some of you guys might have some tips for me. I'm sure some of you guys have used these so I'd really appreciate your advice on these tracks. Any tips at all, from assembly to paint to whether or not I need to glue them once they're assembled and anything else y'all think might be helpful to me. Airplanes don't have tracks so this is a new experience for me, and I'm hoping to learn as much as I can before I begin.
Thanks a million, Guys.
Gary
Detroit, where the weak are killed and eaten. Bwahahaha
    May 2011
Posted by AceHawkDriver on Wednesday, December 14, 2011 11:03 AM
As far as building the individual link tracks, one of the best tutorials i've seen (and it's a video) is right here on the website.  Try looking under the videos tab above and select "how to".  It will have a demo of assembling the tracks.  Testors pink lable cement is what I use and it works really well.
My favorite method to paint is relatively new and is listed below in the order I've used with success.
1.  Prime assembled tracks with Tamiya fine surface primer or Mr. Surfacer 1000
2.  Basecoat of Vallejo "track primer" (a very dark rust color that is fragile unless over a primer coat)
3.  Wash of Windsor Newton Raw Umber artist oils
4.  Wash of model master rust
5.  Use a drafting pencil (any should work) and rub lightly on the edges of the metal surfaces to give a metallic look
6.  Three different rust shaded pigments in this order:  dark rust color (dark reddish brown), light rust color (brownish orange), and a newer rust color (lighter shade of the light rust color.
It has worked for me in the past and looks good when complete.  It'll depend on what theater and type of environment it will be in though (i.e. north africa vs. normandy).  Sorry for the long post but hope it helps!
Peace through superior firepower.
Brian
