Tiger variants
    March 2011
Tiger variants
Posted by modeler#1 on Wednesday, December 21, 2011 4:49 PM
Which Tiger variants whould be classified as Mid production?
On the Bench: Nothing atm
Posted by Bish on Wednesday, December 21, 2011 4:53 PM
I assume you mean the Tiger I. There was only really one Tiger I variant, the Sturmtiger. I believe most if not all of the 18 built were converted from late production models. There was the so called Bergetiger, but this was a one off.
There was also the command versions, these would probably have been on Early, Mid and Late.
    August 2005
Posted by Phil_H on Wednesday, December 21, 2011 4:59 PM
Visually, the most obvious feature of the mid-production units is that they have the lower cupola but retain the rubber-rimmed cast roadwheels. (I'm sure there are other differences too)
    March 2011
Posted by modeler#1 on Wednesday, December 21, 2011 5:14 PM
Let me rephrase my question, Would the Tiger I Ausf E be classifed as Early,Mid or Late production variant.
On a side note did the King tiger have same tracks as the Tiger?
    January 2008
Posted by Byrden on Wednesday, December 21, 2011 5:29 PM
[1] Yes.  (there was no other Ausf. of Tiger)
[2] No.
David
Posted by Rob Gronovius on Wednesday, December 21, 2011 5:51 PM
modeler#1
Not to be a wise acre, but the Tiger I Ausf. E can be classified as all three depending on when it was built. It was the only Ausf made. If you have a question regarding a specific Tiger kit (don't just say the Dragon Tiger since there are multiple versions) or want to find a specific production (early/mit/late), ask the question in that way.
I hope this helps you formulate your question a little better.
    March 2011
Posted by modeler#1 on Wednesday, December 21, 2011 6:16 PM
Was there a noticible diffrence bettween each production?
Posted by Bish on Wednesday, December 21, 2011 6:21 PM
The Germans never used the terms erly middle or late for obvious reasons. So don't get to hooked up on it.
 During production of the Tiger I, changers were made often on a monthly bases. An Early production built one month could be different to an Early production built the following month. As a basic guide though, early production has the dust bin lid cupola. Mid production had the lower type cupola with the swivel hatch. And late production has the steel road wheels. Bit its only a rough guide.
Posted by tigerman on Wednesday, December 21, 2011 8:28 PM
Most noticable between early and late is the cupola which went from drum to late-war. The Tiger I late stands alone due to it's all-steel wheels.
 Eric
Posted by T26E4 on Thursday, December 22, 2011 5:34 AM
This might help you:
http://www.missing-lynx.com/panzer_facts/pftiger.htm
And like someone else said, don't get hung up on the labels "early", "mid", or "late".  They were post war (modelers and vehicle researchers) constructs.  For the Germans, they just made TIGERS and added upgrades as needed/wanted.
Roy Chow
Join AMPS!
http://www.amps-armor.org
