What Psi should I spray at?
    March 2011
Posted by modeler#1 on Wednesday, December 28, 2011 3:00 PM
I am new to the airbrushing and was wondering what psi I should be spraying at for gereral covrage?
On the Bench: Nothing atm
    March 2010
Posted by ACESES5 on Wednesday, December 28, 2011 3:18 PM
Modeler#1: I use ModelMaster and Tamyia paints I use no more than 15lbs. of pressure thin your paint to a consistatey of milk.               ACESES5                    2 cents
    March 2010
Posted by Hercmech on Wednesday, December 28, 2011 3:19 PM
It would depend on the consistency of your paint, your needle size and numerous other factors. The thinner your paint the less your psi will have to be generally. Pick a PSI...sy 12 and start spraying on a scrap piece and adjust to your liking.
13151015
Posted by tigerman on Wednesday, December 28, 2011 5:12 PM
Depends on your air source as well. For a general base coat, I spray around 35psi. For camo, closer to 20-25. It really depends on the air source. Practice on an old model if you can for best results.
 Eric
    July 2006
Posted by redleg12 on Wednesday, December 28, 2011 8:55 PM
There are many variables but between 15 - 25 psi, depending on the paint type, the viscosity after thinning, and the airbrush needle size. I keep a couple of paint booth cows....old models for test shots...its the best way to check.
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    May 2008
Posted by Boba Fett on Wednesday, December 28, 2011 9:29 PM
For my model-master acrylics (minimally thinned) in  a Paschee VL with the high-flow needle, I always spray at around 20psi. That seems to give me the best paint flow while keeping it controllable. The lowest I will EVER go is about 15. Now I like to spray a bit thicker paint, so that's why the pressure is higher.
