hairsprat tech...
    May 2010
hairsprat tech...
Posted by salvine on Friday, January 13, 2012 4:17 PM
After reading the section in FSM it looks like you just spray a coat and then your white coat and scrape away the white with a coarse brush huh? Any other tips. Trying it out on a 1/144 Tiger.
    November 2007
Posted by Lufttiger on Friday, January 13, 2012 5:00 PM
That's about it, but with that scale you better go a bit slower. Maybe start with some water first
and see if it comes off enough for you. If not try 70% rubbing alcohal. Don't wait too long after
you put on the white wash to brush it off. I did it right after i was done putting it on.
Good Luck
www.lufttiger.com
