'K, folks. I've got an AMT BMP-1 and Soviet T-72 at nearby comic shop for $10 both. They are still wrapped in the original plastic. How good are they in terms of fit and accuracy. Are they worth the time and resources to put them together, or should I display them as collectibles?
Merkava IV: As some of you know, I'm working on Academy's 1/35 Merkava IV LIC. There is an optional machine gun by the cannon that seems to me like it is operated remotely. If this is the case, I believe some wiring is in order and I have wandered the web for reference pictures with no luck. Not all Merkavas have this gun installed and when I see pictures of them with the gun installed, they are taken from a distance. A picture from above would be great. Any help will be greatly appreciated.
George
since they are AMT the amount of detail probably isnt that good. the moldings are probably pretty thick. most of the AMT car kits are like that so i cant imagine that the armor kits are much different.
1/35 XM77 "Sledgehammer", 1964 Chevy Impala Derby Car
Whats next? Aircraft for Ground Attack Group Build
"I dont just tackle to make a play, I tackle to break your will." -Ray Lewis
"In the end, we're all just chalk lines on the concrete, drawn only to be washed away"- 5 Finger Death Punch
"Ahh, my old enemy.......STAIRS"- Po, Kung Fu Panda
The AMT (it is a US boxed Esci kit) BMP-1 was the better of the three available BMP-1 kits that arrived in the late 80s and early 90s. The other two being the DML kit (still available in Zvezda boxing) and the incomplete Lindberg BMP-1U.
The Esci T-72 and the similar "T-74", on the other hand, were based off of grainy Cold War photos and designed before the fall of the Berlin Wall. Its accuracy is suspect and rendered obsolete with the arrival of the Tamiya T-72.
When completed, it does look like a Soviet era tank, but is not a realistic prototype of any particular variant of T-72.
TheWildChild since they are AMT the amount of detail probably isnt that good. the moldings are probably pretty thick. most of the AMT car kits are like that so i cant imagine that the armor kits are much different.
