1:35 Bronco Staghound Mk1
    April 2011
Posted by psgavin on Thursday, February 9, 2012 9:35 AM
     This is a fairly straight out of the box 1:35 Bronco Staghound Mk1. The kit was fun to build and went together fairly easy in spite of the questionable instructions that Bronco provides. It was less step by step and more exploded diagram. They also had the sequence starting with you adding all the bits to the hull sides before building the hull assy. It was much easier to build the hull then add everything else.
    The hardest part of the build I thought was making the tank straps, the Bronco PE was soft and bent very easy but there were NO fold lines so you were guessing on all your folds. The straps I ended up with were a little long and didn't quite look right once joined to the hull. The other issue with with the kit was a total lack of interior, there was good detail on the inside of the hatches and the guns were also well detail PLUS the radio looked nice but why?? With no other detail inside it was almost pointless to build up the radio but I still did it and left the hatches open.
This is also my first attempt at heavy weathering on a kit, as a former car guy it sure felt strange to do a nice paint job then cover it all back up lol.
Thanks for looking and please let me know what you think.
Intellectual growth should commence at birth and cease only at death.
Albert Einstein
    March 2010
Posted by Hercmech on Thursday, February 9, 2012 10:07 AM
Very nice build  your shading is really spot on to me.
13151015
Posted by Anonymous on Thursday, February 9, 2012 10:12 AM
Very nice...the mud is good but you can make it better by adding a little splatter and maybe varying the "dryness" of it a tad...if interested, ask me how...
Posted by Gamera on Thursday, February 9, 2012 10:25 AM
Very nice job! I suppose the mud could use a little variation too but I'm just nitpicking. Kudos sir! Toast
I like to leave the hatches open and put figures on the vehicle which blocks most of the view of the interior. Except the front driver's view ports wouldn't be blocked that well by a driver figure so I'm not sure what would be best here.
    July 2004
Posted by wbill76 on Thursday, February 9, 2012 1:44 PM
Nice work on it, the first pic you showed is the best one IMHO, really shows off what you accomplished with the paint job. I agree with the other suggestions on the mud effects...it's always a balancing act to achieve a realistic appearance between the wheels and tires, the wells, and the fenders, but you've done good for your first attempt at it. Beer
    July 2007
Posted by Utoshita on Saturday, February 11, 2012 10:10 AM
Congratulations on e very good build Gavin.
I am very much impressed with your overall finish.
Got the same kit in the stash but a version with rocket rails.
Thank you for sharing your pictures :)
Kind Regards
Utoshita
Deliriant isti Hominem!
    January 2012
Posted by Von Sisco on Monday, February 13, 2012 8:30 AM
Really nice build Gavin. I agree with you, it's tough coming from automotive models and trying to achieve a flawless finish to weathering and making 'em look worn out. But you have done an excellent job!
Ed Sisco
On the bench: 1/48 Hobby Boss F3H-2 Demon & 1/48 Trumpeter F9F-2 Panther
On deck: 1/48 Grand Phoenix FJ-4 Fury double build
