painting rubber on the tracks
    April 2008
Posted by zapme on Friday, February 10, 2012 4:59 AM
Hi everyone,
I've just started work on my C1 Ariete and have been studying the tracks. This is the first time I've encountered rubber on the tracks. could anyone provide any short cuts on painting this rubber as I'm not looking forward to hand painting every one. Also does flat black sound like a good colour or is there some paint out there that resembles rubber?
Thanks
Leo
My Blog - leoslatestbuilds.blogspot.com
On the workbench: 1/72 Airfix De Havilland DH88 Comet , 1/35 Trumpeter M1A1, 1/35 Tamiya Tyrannosaurus Rex, 1/8 (?) vinyl C3PO brand unknown
    October 2008
Posted by P mitch on Friday, February 10, 2012 5:05 AM
Hi Leo
I've worked a couple of times on tracks with rubber. The way I did it was to use the normal way of painting tracks, I use an airbrush and Tamiya's red brown as a base. When that was dry I use Vallejo dark rubber paint ( I looks just like rubber when dry). Using a flat brush I just run it across the rubber pad and in one pass per link its done. I know it can take a while to get a full run painted but its the only way I know to get a look that looks close to real. it doesnt have to be neat as the pads themselves will have been damages so will have a rough look anyway.
Hope that helps
Phil
"If anybody ever tells you anything about an aeroplane which is so bloody complicated you can't understand it, take it from me: it's all balls." R J Mitchell
    July 2006
Posted by redleg12 on Friday, February 10, 2012 5:32 AM
Well.....the only shortcut is not to paint the rubber on the tracks that will not show!! The brush is the only way....link by link
Rounds Complete!!
"The Moral High Ground....A Great Place to Emplace Artillery."
    August 2006
Posted by K-dawg on Friday, February 10, 2012 8:50 AM
Leo, Here is an example of a rubber and metal track I did last year. The tracks were painted Tamiya Nato Black then lightly sponged with various light grays and finally a VERY light dry brushing of a medium gray.  I then masked off the black with strips of tape on both sides and then airbrushed the end connectors and guide horns. The rusty tone was furthered with more sponging and some light color washes. I washed on a thin pigment slurry to blend it all together. A subtle black wash in the deepest areas help hide the demarcation between the rubber and metal. With this technique you will have a little over spray of rust on the sides of the track pads where it should be rubber but it's hardly noticeable as you can see.
Kenneth Childres, Central Arkansas Scale Modelers
Posted by tigerman on Friday, February 10, 2012 8:59 AM
Those tracks look great Kevin.
 Eric
    April 2008
Posted by zapme on Saturday, February 11, 2012 4:05 AM
Thanks guys, mighty helpful. its off to work I go. Wife, put the kettle on, I might be a whileBig Smile
