USMC M4A3 Dozer Riff Raff . Camera broke . No updates . 6/3
    March 2006
Posted by Shellback on Wednesday, March 7, 2012 10:54 PM
I've had this two kits sitting in my stash for many a year ............just sitting there . Then i got to building them when i participated in a G.B. "Semper Fi , war in the Pacific " .
As you know there is nothing covering the bottom of the sponsons on this old kit so i made a frame work out of sprue pieces and and then glued sheet plastic cut from a plastic "for sale" sign to the sprue frame .
I "raised" the weld seams on the hull raised above the plates by glueing stretched spue over the "recessed" welds and using a hobby knife blade to create weld beads in the glue softened plastic .
The seam between the glacis plate and hull side plate was a simple goove so i used a "V" file to recess and widen it and then added the weld.
Ok , nuff for now ,photo bucket keeps freezing up on me ..........Super Angry............... i'll be back tomorrow ......................Yes
    July 2003
  • From: On my kitchen counter top somewhere in central North Carolina.
Posted by disastermaster on Wednesday, March 7, 2012 11:31 PM
https://encrypted-tbn3.google.com/images?q=tbn:ANd9GcS-ZpRJMKfdGzGx84QRM6JowmKiNrjfhhziVMWoqyVZ07vyY-4fqlCp Hmmmm...
 Looks like something I did a while back.......
    Should look ominous with that dozer blade.
 https://i.imgur.com/LjRRaV1.png
Posted by T26E4 on Wednesday, March 7, 2012 11:35 PM
Nice work so far!  Maybe you've already seen this tweaks list before...
http://www.usarmymodels.com/MANUFACTURERS/Tamiya/tamiya35122.html
Roy Chow
Join AMPS!
http://www.amps-armor.org
    March 2006
Posted by Shellback on Thursday, March 8, 2012 1:30 AM
Disaster , i remember your last Sherman build here ........darn good looking piece . Do you have a link to it ? I cant remember the name of it and i'd like to look at it again .Yes
    March 2006
Posted by Shellback on Thursday, March 8, 2012 1:33 AM
T26 , thanks for that link , much appreciate the offer . I filed it away in my favorites when i was doing research on this model . Good info there that has come in handy already . Yes
    March 2006
Posted by Shellback on Thursday, March 8, 2012 1:38 AM
T26 , i found this little tid bit at that link , these drain holes for the splash guards on the upper hull . I never noticed them before .Yes
    July 2004
Posted by wbill76 on Thursday, March 8, 2012 12:12 PM
Looks like a fun project Carl, look forward to seeing this one come to life. Nice work on the weld seams and other little details. Beer
    March 2006
Posted by Shellback on Thursday, March 8, 2012 1:00 PM
Bill , its been fun alright . The research has been interesting . i'm still looking for more info .Yes
I know you experienced builders dont need the info below so concider it blah blah blah if you've got it figured out already ......................Yes
The transmission cover looked to smooth for me . Since its a cast piece i thought it needed to look a bit more .........well "cast " . I understand that this can be over done , especially  for the "scale effect" but i bit the bullet and went ahead and textured the cover more . I used Testors plastic cement in the purplish labeled container . After stippling it on i let it cure and sanded off the roughest of the texturing .
Then appied another coat of liquid cement to smooth down the sanded surface and shot a thin coat of primer to see how it looked .
Posted by T26E4 on Thursday, March 8, 2012 5:27 PM
That looks good. I always make sure I add the bolt strip at this point and ensure no seam btwn the finshed areas of the bolt strip and the cast texture of the main body of the differential cover.
Roy Chow
Join AMPS!
    July 2003
Posted by disastermaster on Thursday, March 8, 2012 8:00 PM
Shellback
http://i38.photobucket.com/albums/e105/CommentCrazyGirl/Smileys%20Hello%20Wave/peek.gif  Looks like you done found it.
 If you didn't, well just click on the http://www.ilovephilosophy.com/images/smilies/text/link.gif image that's at the bottom of all my postings and replies.
 BTW, that texture looks factory fresh...... some very good glacis results for the average working Sherman.
Very nice.
    March 2006
Posted by Shellback on Thursday, March 8, 2012 9:19 PM
T26 , thanks for that reminder . I'll make sure that seam is sealed .Yes
    March 2006
Posted by Shellback on Thursday, March 8, 2012 9:22 PM
Disaster , i never saw that link at the bottom ...........cant see whats right in front of me .Geeked
    March 2006
Posted by Shellback on Thursday, March 8, 2012 9:26 PM
Thanks for the help T26 and Disaster . I have the aft lower hull finished and primered .I did a little texturizing on the exhaust pipes . I dont think these were cast (were they?) but i wanted some texturing on them when i rust them up a little later on.
    August 2006
Posted by ogrejohn on Friday, March 9, 2012 3:50 AM
Mighty fine looking work Carl!
Posted by BaBill212 on Friday, March 9, 2012 4:46 AM
Great work Carl,,,,,,,,,,,  !!!
Enjoy the ride!
    July 2003
Posted by disastermaster on Friday, March 9, 2012 5:55 AM
http://www.marseilleforum.com/forum/index.php?action=dlattach%3Battach=3343%3Btype=avatar
Humming along just nicely....... http://espaciojapon.com/foro/images/smilies/icon_note.gifhttp://espaciojapon.com/foro/images/smilies/icon_note.gifhttp://espaciojapon.com/foro/images/smilies/icon_note.gif
    January 2003
Posted by p38jl on Friday, March 9, 2012 12:29 PM
Looking good Yes
[Photobucket]
    March 2006
Posted by Shellback on Friday, March 9, 2012 8:44 PM
Hey guys ,Beer
I added this copper wire to the eye on the bottom of the gun craddle . I'll paint it to look like a rope later . I saw a rope attached like this in one of my reference excursions .
The support brackets for the blade hydraulic mechanism .Not much info inthe Verliden instructions on how this is all attached . I was able to get a little peak at the hooks ups from a couple of pictures ,but nothing conclusive . I ran plastic rod thru the brass plates and then the pintle hook eyes . Hopefully this is close .
    January 2006
Posted by SprueOne on Friday, March 9, 2012 8:59 PM
Following this build. Sometimes you just have to engineer the build yourself, however you think it's will work. Cool, nice progress so-far
Anyone with a good car don't need to be justified - Hazel Motes
Iron Rails 2015 by Wayne Cassell Weekend Madness sprueone
    March 2006
Posted by Shellback on Friday, March 9, 2012 9:27 PM
Sprueone , True .............Yes
Oh yes , noticed i broke off the starboard headlight guard when i looked at this picture closer ..........i spent an hr working on that thing making it thinner Super Angry Also i made brackets and sorda chains to hold the plugs that cover the holes where the headlights are removed from . I'll be leaving the bow M.G. out of its mount also . Doesnt look like it would be of any use with the blade blocking it .
    September 2005
Posted by treadwell on Friday, March 9, 2012 11:39 PM
Hi Shell  : )  .... long time man !
the weld seams look really goodBeer  digging 'em out first really makes them look a lot better
and the glacis cover texture looks really nice. I don't know if you were planning on adding  the 'comb' device, but I know it would be totally appropriate for your build.     Here is a link to some different styles:        http://web.inter.nl.net/users/spoelstra/g104/comb.htm
 http://web.inter.nl.net/users/spoelstra/g104/comb_brakelock.htm
this is gonna be a beauty,ShellStick out tongue
treadCool
    March 2006
Posted by Shellback on Saturday, March 10, 2012 12:20 AM
Well Tread i hadnt thought about the "comb " b4 you broughtit up ..............sounds like a good idea though .Yes
    March 2006
Posted by Shellback on Saturday, March 10, 2012 1:29 AM
Steve , i went thru your thread on your "Jumbo" .......Wow.........thats an outstanding build . Just wanted to say that .Yes
Posted by T26E4 on Saturday, March 10, 2012 10:42 AM
Shellback: things looking good so far.  I think you may have placed the gun travel lock on backwards/front however.
Also I don't recall the finer details of the VP M1 Dozer (I traded mine away before using it).  However, I built up the Resicast version and found some of its part rather clunky.  I replaced them w/styrene.  You can see what I did here:
Hope this helps.
Roy Chow
Join AMPS!
Posted by T26E4 on Saturday, March 10, 2012 10:43 AM
Also, here are some good pics of an M1 survivor
http://www.ferreamole.it/images/tankdozer/tankdozer.htm
This Sherman has the cast nose so I think you can see how the lower frame attaches to it in the pics.
Roy Chow
Join AMPS!
    July 2003
Posted by disastermaster on Saturday, March 10, 2012 3:59 PM
Shellback
Ahh gee....
http://i24.servimg.com/u/f24/13/64/32/21/bashfu10.jpg
I thank you.
    March 2006
Posted by Shellback on Saturday, March 10, 2012 5:22 PM
Steve , one question , where did you get your inspiration for the re bar and chicken wire ? Ooops , 2 questions .
Thanks for the link to your build .......... Yes
    March 2006
Posted by Shellback on Saturday, March 10, 2012 5:30 PM
T26E4
http://i45.photobucket.com/albums/f74/ericadeane/M4A4%20Scarifier/037.jpg
Hope this helps.
On backwords .............hmmm ...........i will look . Roy i found your thread on the above build of yours . The hydraulic cylinder certaily is larger than the one provided by Verlinden . Looked like an interesting build but i couldnt find  the thread with the finished scratch built blade  ......the blade you made looked like something found on a M1 Abrams , cool is what i'm sayin Yes Thanks for the pic and help .
    March 2006
Posted by Shellback on Saturday, March 10, 2012 5:57 PM
Roy , heres the problem . I used the gun cradle from an Italeri kit M4A1 . Here's a pic of the differences . The Tamiya kit cradle is sitting to the right side of pic .Thanks for catching that ..................Yes   Beer
    March 2006
Posted by Shellback on Saturday, March 10, 2012 7:19 PM
Fixed . Appreciate the help Roy .
